![]() Join Date: Jul 2009
Stupid Question
Can anyone tell me how to get the inside door latch and window handle off? I'm pretty handy but don't want to break it in the process of taking them off. Thanks...
Between Trucks...
Re: Stupid Question
There are little clips that hold them on. There's a tool you can buy to pop them off, or you could try a screwdriver.
Beat it to fit, Paint it to match... ![]() |
Dave's not here, man
Re: Stupid Question
x2...I never bought the tool, although I think it makes it easier to reinstall. I have always used a screwdriver, but be sure to shield the clip with your hand because they have a tendency to go flying. You should be able see the clip if you pull slightly against the handle or window crank. If you don't have the tool, you can make the reinstall easier by setting the horseshoe clip part-way over the base of the window crank or door handle, then slip it back on the crank assembly and push it on the rest of the way with your screwdriver. I hope this makes sense...
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 08-04-2009 at 08:47 PM. |
Lemme show you something!!
Re: Stupid Question
I've never bought the tool 'cause I'm a poor white boy from the ghetto. I've also fiddled for long periods of time with a screwdriver. The best, quickest and safest method I've found is to take a clean shop rag, pull it tight and slip it down between the handle and door panel. Hold one end and start wrapping the other clockwise around the latch or window regulator shaft. Once you get past 1/2 way around start pulling both ends in a clockwise direction. More often then not this will pop off those horseshoe clips 1st. try.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
its all about the +6 inches
Re: Stupid Question
Re: Stupid Question
almost forgot to say... no such thing as a stupid question.
Re: Stupid Question
Awesome pics...did you take those? Those pics show exactly what my ramblings were attempting to convey
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 08-04-2009 at 10:02 PM. |
![]() Join Date: May 2009
Re: Stupid Question
Also, the clip should be installed as in the top picture above. When you do install the clip, a pair of needle nose pliers works well.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
70 Chevrolet=Obsession
Re: Stupid Question
I don't know if my truck is different but when you reinstall the handle and crank just fully install the clip on the back of the handle/crank and push it on to the post. the beveled end of the post lets it slide right on. BTW I have that removal tool and it works great and was only six bucks.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
![]() ![]() Join Date: Dec 1999
Re: Stupid Question
The tool for that is like $6 bucks at any autoparts store.
Can't afford not to have one.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#11 | |
Re: Stupid Question
Here's a pic
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
Re: Stupid Question
No, yours is not different, that's the correct way to install. But, sometimes trying to get the clip into the slot is awkward and holding the clip with pliers makes it a lot easier.
#13 |
Re: Stupid Question
i didn't take those photos... I did a google on the topic looking for the rag trick pic.
#14 |
I am a Referee of life.
Re: Stupid Question
I use a 1/8th welding rod that i hammered the flux off of and flattened the end.Then I put a very short bend in the end.Works well.
BTW You will need to go to the parts store and look in the "Help!" sectioon.They have a package of assorted "JESUS" clips for a couple bucks.I have yet to do this without loosing a clip.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#15 |
Re: Stupid Question
I aways use a butter knife it's thin and easy to get behind the handle.
#16 |
Re: Stupid Question
I used a small flat screwdriver that i bent so it would fit behind the handles.
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
#17 |
Re: Stupid Question
I bought the tool today, thanks for all the help.....
