Crooked Frame?
I'm hoping for some help.....
When I got this truck, I was amazed that it had absoultely no rust and I believe it is oem metal everywhere. When I took this truck apart, I didn't see anything that would have led me to believe that the frame was bent (body lines). Once I had it on the stand yesterday, something just didn't look right. I put a string on it from the measured center of the front cross member to the measured center of the rear. The measurement on the front half from side to side are all off. I then put strings on either side and "eyeballed" them to line up along the rear section (I realize a small error at the back could multiply up front) and it seems to be off. I'm assuming that the frames from the factory were symetrical. the last couple pics show what I think are wrinkles. Are there "wrinkles" from the factory? Is this frame "tweaked" Anyone got a cheap SWB 2wd 1978 frame? ![]() ![]() ![]() As always, thanks for the wealth of knowledge!!!!! Misled |
Re: Crooked Frame?
...last two...
Cheyenne Super
Re: Crooked Frame?
I see where it was straightend in the 2nd from the last pic, but in the last pic
that looks like the part just behind the cab, and that one side of the frame looks bent on all trucks, it's bowed down where the other side is flat. The wrinkled part should be repairable. |
Happy to be here
![]() Join Date: Mar 2000
Re: Crooked Frame?
In the last set of pics, the bottom one is correct. That is a curve the factory put there to clear those old humongous catalytic converters.
The other pic is a different story. All those wrinkles are all wrong. It appears that the frame was tweaked and someone did a hack job on trying to straighten it out.
great southern land
Re: Crooked Frame?
yep, looks like it was really bent at some stage, it should be able to be fixed, but it will take alot of heat to get the creases out, and i dont like heating chassis..
rod ![]() 86 chevy c10 silverado |
Re: Crooked Frame?
....that's what I was afraid of.....I guess I'll start looking for a donor frame!!!
Thanks folks!!! Misled |
#7 | |
Garage wrench
Re: Crooked Frame?
That or take the bare frame to a local frame/collision shop and see what they can do for you. It may or may not be the cheaper option.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
