Old 08-04-2009, 11:09 PM   #1
chrislehr
Engine n00b
chrislehr's Avatar
quick - 70 Chevy C/10 - Drum brakes - what size brake drum retainer clips
3/4 or 5/8?
HALP!
chrislehr is offline   Reply With Quote
Old 08-04-2009, 11:45 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: quick - 70 Chevy C/10 - Drum brakes - what size brake drum retainer clips
Chris, I'm trying to remember which clip you are referring to. Do you have a pic?
And are you talking front or rear drums? I'm not sure if they are different, but I might be able to send you what you need if it's for the front.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-05-2009, 06:51 AM   #3
JimKshortstep4x4
The only drum retainer clips that I am familiar with are the ones that fit over the studs to hold the drum in place. The clips are made from flat spring metal and are a push fit over the studs which for a 70 C-10 would be 7/16".
I thought everyone just tossed the clips as the wheel when bolted on keeps the drums in place.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-05-2009, 07:04 AM   #4
cdowns
cdowns's Avatar
yeah if its those clips they're not needed/they were just used on assembly line to keep drums in place before the vehicle got to the tire install area
