zed frame
I was looking here but dont see any info about how you mount the radiator after you z a frame on a 60-66. any pics? thanks
![]() Join Date: Aug 2005
Re: zed frame
From what I've seen you step the frame horns back down a few inches behind the core support so the radiator and core support sit exactly where they did before.
#3 | |
On the fast track to nowhere..
Re: zed frame
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
Re: zed frame
The difference is the radiator mouns is farther back (closer to the engine) on 6x-66's vs. post-67's.
I'm curious about this one as well. How about notching & boxing the frame to allow for dropping the radiator down the necessary amount? Or a shorter in height but longer in length custom radiator??
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-05-2009 at 01:49 PM. |
Re: zed frame
YA. the radiator mount is just behind the coresupport mount so if you lower the coresupport/bumper mount the radiator mount will stay the same.I was also wondering if you install a 73-87 crossmember will the front wheels stay centered ?
100% gearhead
Re: zed frame
The front wheel sstay in the same location. The geometry was all the same on '60-87 front ends. As for the radiator, I usually modify the stock or make a new bracket for the radiator. But, if you use an aftermarket aluminum rad (I use the inexpensive Northerns), the stock bracket will work on the '63 and up trucks if you're going for a 3" Z!
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
Happy to be here
![]() Join Date: Mar 2000
Re: zed frame
Imperial Kustom- Got any pics? This would help a lot...
100% gearhead
Re: zed frame
Actually, I have a bunch, but i don't have the software!! I'll have to get to my buddy's house and upload 'em for ya!
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. Last edited by Imperial Kustom; 08-06-2009 at 02:48 AM. |
Re: zed frame
cool. looking foward to seeing the pics.thanks
#10 | |
Re: zed frame
