Old 08-05-2009, 12:20 AM   #1
1moretoy
Unhappy ls1 swap clearance problems help
i have a 70 short step and trying to swap in a 01 ls1 f body motor using s&p motor plates and the stock sbc rubber mounts,and im having some clearance problems. first, the point on the s&p plate hits the ac comp brkt. so i had to take that off just so i could mount the plate to the block. second, the oil pan hits the crossmember and i only need to move the motor back about an 1" to 1.5" to clear it. can i unbolt the factory perch's wich are mounted in the front holes, move them back and drill new holes?any issues doing that, if i do that will my nice new thorley headders still work? thanks in advance.
1moretoy is offline   Reply With Quote
Old 08-05-2009, 01:35 AM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: ls1 swap clearance problems help
i dont see why not....someone will chime in who has done it...
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 08-05-2009, 01:46 AM   #3
slosteve
Check out the Post "Time to ask the experts" by Mikeys68. It might answer 1 of your questions.
slosteve is offline   Reply With Quote
Old 08-05-2009, 08:28 AM   #4
1moretoy
thanks any 1 else
Old 08-05-2009, 11:55 AM   #5
Shon
Which mounts/plates did you get from them?
I am using the trans dapt plates with stock stands and Poly bushings and everything clears just fine. I would guess you need the other style plates they have.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 08-05-2009, 01:21 PM   #6
revn67
revn67's Avatar
sorry to hi-jack the thread, but what is the part # for the those trans dapt plates shon? and 1moretoy if you cant find a good answer on here (which i know i've read about this somewhere on here.) try either searching for ls1's in a thread or try ls1tech.com
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 08-05-2009, 01:28 PM   #7
Shon
4572
$60 shipped from Herron Performance
Old 08-05-2009, 01:56 PM   #8
Rogue Willie
Rogue Willie's Avatar
That is about the same setup I have. I slid the motor back and redrilled the holes. My Thorley headers fit fine. Haven't fired it up yet.
69 C-10 in progress
Rogue Willie is offline   Reply With Quote
