Old 08-05-2009, 12:56 AM   #1
hotrod0688
69 Rear End
I've got a 69 6 cyl with the stock rear end 6 lug. I need to change it to 5 lug but I was wanting to keep the stock rear end just change the axles does anyone know what axles from something else might fit? thanks
hotrod0688 is offline   Reply With Quote
Old 08-05-2009, 06:46 AM   #2
JimKshortstep4x4
Re: 69 Rear End
The 69 axles are shorter then the 5 lug axles so there is not a direct axle swap. You can swap out the whole rear end or have your axles drilled for the five lug wheels.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
