Old 08-05-2009, 02:24 AM   #1
CrazyIvan
Where exactly are the engine numbers?
Hey guy's
Going to be under the truck repairing a brake line and was thinking that this would be a good time to clean my engine whilst its up on the stands. It is the dirtiest engine I have ever saw!
My question is - Where is the engine number on a 350, and how do I know if the VIN & engine numbers match?
Maybe a dumb question, but not if you dont know the answer.
Cheers
CrazyIvan is offline   Reply With Quote
Old 08-05-2009, 05:19 AM   #2
JimKshortstep4x4
Re: Where exactly are the engine numbers?
The VIN number is stamped on the right side of the engine on a small pad that is in front. The head is adjacent to the pad but the numbers are readable as the head does not cover them.
There is also a casting number on the rear of the engine on the curved area of the casting where the transmission bolts up.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-05-2009, 07:10 AM   #3
mrein3
mrein3's Avatar
Jim
You'll want the number on the front of the engine. The casting number on the back will only give you a vague idea of what you have. The front one, if original, will have part of the VIN number of your truck and a 2 or 3 letter code which you can look up on various websites to determine if it is original or if not, where it came from.
If the engine is dirty, squirt a little WD-40 on a rag and wipe off the pad where the numbers are stamped. The 'pad' is on the right hand side, in front of where the head bolts on to. If you have AC, it is under the compressor.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-05-2009, 07:24 AM   #4
CrazyIvan
thanks, I will be finding it as soon as i get off work. Hopefully its original as it lets me have a better idea of what I have got.
