Old 08-05-2009, 09:53 AM   #1
merlinman572
changing rear gears how hard is it
hi im just getting into drag racing and want to try a new set of gears in my axle its a ford 9 inc with spool and would like to do as much work as poss on my own any advice would be greatfully recieved.
merlinman572 is offline   Reply With Quote
Old 08-05-2009, 10:13 AM   #2
70k52wd
Blaze-Air
70k52wd's Avatar
Re: changing rear gears how hard is it
That's a third member rear. Some drag guys have a couple of centers set up with different ratios for different conditions. I would just get a third member with the ratio you want to try. Keep the set up you have. But then, I don't know how to set a rear up, so for me that is the easy way to get what you want.
70k52wd is offline   Reply With Quote
Old 08-05-2009, 01:37 PM   #3
red caddy
For my nickel, the Ford 9 is the easiest chunk to setup. There are several good tutorials availible on the net, just google Ford 9. (check out Pirate 4X4 .com) The first one I did took most of a day, now I do one in less than hour. The only tools required are a mag base dial indicator, a good dial caliper or 0 to 1 micrometer, a torque wrench, and common hand tools.
I built a bench fixture to hold the chunk, much easier than chasing it around the shop floor.
Both my race rig's use the 9, so I've accumulated a dozen or so chunks, from 2.46:1 to 5.12:1, 31 and 35 spline. Plug N' play at it's best. Good luck, Paul
red caddy is offline   Reply With Quote
Old 08-05-2009, 04:06 PM   #4
merlinman572
thanks for advice will go on line and do some search's have all the tools you described at moment running 3.7-1 on 33 tyres with 572 merlin block kickin 628hp 700lbft on dyno in c30 full size crew cab nearly 3 ton running 13.07 @102mph was thinking of trying 4.3-1 gears
Old 08-05-2009, 09:50 PM   #5
ImportThis
use an impact to tighten the pinion nut, because if you use the old style crush sleeve you wont crush the sleeve by hand. you want to set your backlash at .003-.006 for a drag race application on a 9"(as long as you are using new R&P)
an impact with 9/16", 3/4" and 1 1/16"(im pretty sure for pinion nut) impact sockets should pretty much do ya, except i use a wrench for the keepers. make sure to red locktite the ring gear bolts, and blue locktite all other bolts and torque to proper spec.
i agree red, i have done a hundred or so 9" chunks, mainly for circle track cars, and they are by far the easiest to set up, and being able to swap complete chunk on the go is great.
ImportThis is offline   Reply With Quote
Old 08-06-2009, 11:54 AM   #6
red caddy
WOW, that's a helluva rig, COOL.
Are you running 1/8th or full quarter? In the 1/8th, 4.30's should be fine, but unless you are spinning way past 6000 and growing those 33's the MPH will still seem low. What launch and shift RPM work good for you now? RED
Old 08-06-2009, 12:33 PM   #7
merlinman572
i am still very new to this built it for street fun but now i tried the track im hooked ha will dig out my slips and post really green to all this so all advice most welcome like tyre pressures and type have transbrake turbo 400 but not used transbrake yet been advised to do something with rear springs so taking it stage by stage but lovin it
Old 08-06-2009, 12:37 PM   #8
merlinman572
sorry running quarter mile
