Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-05-2009, 01:04 PM   #1
87Bob
A/C Clutch removal
In order to get the compressor off the bracket I have to remove the AC Clutch. I got the nut off the center of the AC Clutch how do I get the rest of it off? Thanks!
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 08-05-2009, 04:46 PM   #2
lvschevytrucks
Unfinished Project Club
lvschevytrucks's Avatar
Re: A/C Clutch removal
are you talking on your 4.3?
if you are just remove the three nut and bolts they run through the body of the unit and pull the whole thing up and out. The bolts have one side of the head ground down so it will slide past the A/C clutch . hope this helps Randy
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
1996 Dodge Intreped ES Nice car great on gas
1993 Jeep Cherokee.
Looking for a swb chevy 73-87
lvschevytrucks is offline   Reply With Quote
Old 08-05-2009, 06:51 PM   #3
87Bob
Not on mine they hit the pulley. The clutch has to come off.
Old 08-06-2009, 09:14 AM   #4
87Bob
UPDATE: I finally got that bugger off. O'Reily Auto Parts had a kit you can barrow. It has a threaded sleeve that screws into the center of the hub that has a ram screw that goes down the center of it. Then the snap ring and the pulley finally comes off. What an itch if you have never done it before. It is easy now that I've done it. Finding the correct tool is the major battle.
Old 08-06-2009, 03:19 PM   #5
BarryB
BarryB's Avatar
Glad you got it off, I was gunna tell you you'll need an A/C clutch puller. I have one I picked up when I was at carlisle truck Nats last year. It makes the job alot easier.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 08-07-2009, 01:01 PM   #6
lvschevytrucks
Ive never had to pull the A/C clutch even on the 95 S/10 im doing right now. all you have to do is loosen and take off all three nuts on the back of the brace, then you can move the unit around (with a little muscle) and keeping the ground down flat side of the bolt towards the A/C clutch pull the bolt by wiggling it around you can get all the bolts off. Ill take pictures and post them on this thread as I put mine back together, with the A/C clutch on.
but Im glad you got it off. Randy
1993 Jeep Cherokee.
Old 08-07-2009, 02:02 PM   #7
87Bob
Well it worked out ok as I wanted to get the clutch/pulley powder coated any way. Plus I've learned something new.
Old 08-08-2009, 04:39 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
upon reassembly make sure the gap is .012 - .015"
how is the clutch face? is it square and flat or kind of wavy? how is the bearing? you may want to check these out before you powder coat a bad clutch.
68C15 is offline   Reply With Quote
