Old 08-05-2009, 05:05 PM   #1
ozman3803
Pros/Cons of trailing arm coil springs?
I was just curious if anybody has converted to rear leaf springs. I've heard the leafsprings ride much better, better handling and less wheel hop. Is this the case with coil over with trailing arms. I don't know since I never have been able to drive my 70 swb yet. Any reason to keep what I have or is it worth vconverting to leafs?
ozman3803 is offline   Reply With Quote
Old 08-05-2009, 07:00 PM   #2
LONGHAIR
Re: Pros/Cons of trailing arm coil springs?
Seems like you are working the wrong direction.....especially since you haven't driven it, to be sure that you even have a problem?
"Generally" the trailing arm suspension is less likely to have wheel hop problems than the leaf springs, so I wouldn't change for that reason. I wouldn't say that the coils are and stiffer as far as the ride either? so I wouldn't even consider changing....JMO though
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-05-2009, 07:12 PM   #3
ozman3803
Yeah I was just going off somebody elses opinion to. Thanks for the input though. I was just wondering because I have a 77 pickup for parts and I want the five lug conversion. Just thought it might be easier to swap out rearend and I would also be able to get a free at least 3in drop flipping the leafsprings. Any other ideas out there?
Old 08-05-2009, 10:05 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
The only negative I can see about trailing arms is they limit how low you can go. Beyond that they are much easier to lower.
They can't be too bad if it works on the Grand National cars.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-06-2009, 02:35 PM   #5
bmfpeterson
bmfpeterson's Avatar
Not trying to hijack your thread but dose anyone notch out the frame where the trailing arms would hit?? or you might as well back half it?
bmfpeterson is offline   Reply With Quote
Old 08-08-2009, 09:14 PM   #6
Primer70
Superbad
Primer70's Avatar
You can buy lowering blocks for the trailing arm suspensions. This means you can go as low as 7" of drop in the rear with 5" coils with 2" blocks. You'll definitely need a frame notch / bridge kit, shock relocators & cut into the bed though.
Primer70 is offline   Reply With Quote
Old 08-08-2009, 11:30 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
I have one of each...leaf and coil. I think they both ride better then any lowered newer truck Ive driven. I think you can do a flip on leafs cheaper than coils, but neither is very difficult depending on your skills or friends. I would buy the angled axle perches for the rear end swap to 5-lug and keep the coils. Your out the price of the perches and some brake work...DONE!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-08-2009, 11:41 PM   #8
dbmx66
i would keep the coils
dbmx66 is offline   Reply With Quote
Old 11-06-2010, 02:12 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I know this an old thread, but....
Could we get some more opinions on Rear Coils vs Leaf Springs?
66 C20 Service Truck:
Old 11-06-2010, 06:33 AM   #10
raycow
The only good reason I can think of for running leaf springs is that they give you room for 1 or 2 fuel tanks forward of the rear axle. That means you can get the tank out of the cab and keep your spare in the original location. I'm talking about a driver here with a stock suspension, not some kind of 4 link you might see under a show truck.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-06-2010, 11:47 AM   #11
chevy_mike
Never Ending Projects
chevy_mike's Avatar
If you really want to know how well trailing arms work for handling, check any NASCAR car or truck out as they are still using them. Coils will almost always ride better than leafs, just the nature of the design. Downside is coils won't haul as heavy of a load as leafs.
My '65 was a trailing arm setup that a PO swap in a leaf spring setup. I am gathering the parts to swap it back as the TA setup rides and handles so much nicer!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-06-2010, 01:40 PM   #12
LEEVON
Moderator
LEEVON's Avatar
All other things equal, coil springs ride quite a bit better. I can't think of any reason to convert to leaf springs unless you're hauling big loads.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-06-2010, 04:47 PM   #13
stich626
only reason new trucks use leaf set up is it's cheap.
it locates the rearend and is the spring, (less parts)
coils better ride but requires more parts ,
wheel hop can happen with either..
stich626 is offline   Reply With Quote
Old 11-06-2010, 06:13 PM   #14
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I had a '68 leaf spring truck and a '72 coil truck...parted the coil truck except for its rear coil suspension and '72 front end w/discs... and put it all under the '68.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-06-2010, 06:44 PM   #15
m6z
m6z's Avatar
Coils all the way. Why do you think the 2009 and newer dodge half tons use coils. The ride is much smoother with coils.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 11-06-2010, 10:10 PM   #16
Ackattack
Ackattack's Avatar
I just converted my project "No buck" to coils
Let me tell you, a 3/4ton leaf spring SWB truck is ROUGH!
Ackattack is offline   Reply With Quote
