Old 08-05-2009, 08:35 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
automatic linkage bushing
My automatic linkage HAD a bushing that fits in the lower part where the rod goes from the column down to the rest of the linkage. Mine was so bad it crumbled and fell apart. It's plastic, and does anyone know where I can get one? I checked the LMC catalog and zippo. I could try a couple junk yards but a new one would be the ticket. Let me know if you know of a source for one. Thanks
Jim
jcfoote60 is offline   Reply With Quote
Old 08-05-2009, 11:03 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: automatic linkage bushing
The bushings are usually metal and fit snugly intu a rubber grommet. I have used grommets from the small parts bins at Ace or Tru value hardware stores and then cut a sleeve from some small tubing slide the rod throgh and place a flat washer followed by a cotter pin.
Jurassic-1 is offline   Reply With Quote
Old 08-05-2009, 11:22 PM   #3
LUCKTRUCK
LUCKTRUCK's Avatar
try www.classicparts.com, part number 91-064 may be what you're looking for, not sure though ??
LUCKTRUCK
LUCKTRUCK is offline   Reply With Quote
Old 08-05-2009, 11:55 PM   #4
mclairmo
NAPA might carry it in the Dorman line of goodies.
mclairmo is offline   Reply With Quote
