Old 08-05-2009, 09:43 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Arrow cowl leak
okay so on my truck i pulled out the floor mat and found alot of rust.after sanding and priming the floor itook off the cowl and found rust holes under a pile of leaves. after cleaning it out and putting phosphorus on it, i started to layer on some black silicone.
my question is will this work and is there anything else i can do to enshure no more water leaks in because im getting ready to put in my new insulation and floor mat.
thanks yall!
bucannon is offline   Reply With Quote
Old 08-05-2009, 10:21 PM   #2
spr85gmc
spr85gmc's Avatar
Re: cowl leak
pics please i have the same leak
spr85gmc is offline   Reply With Quote
Old 08-09-2009, 03:50 AM   #3
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: cowl leak
here ya go. sorry it took so long for me to upload them. but basically what i did was use black silicone(can be found at home depot) and every spot where the rust was in the cowl i just layered it on, and after a few tries i got the cowl sealed up, and after that i layered on a thick coat of primer to seal it just a little more.
as a final test i got a garden hose and let it sit n the cowl running and i moved it all over. and the cab was bone dry! so it worked and my new insulation and floor mat are in!
heres the links to the pics:
http://jamandjoe.bravehost.com/001.JPG
http://jamandjoe.bravehost.com/003.JPG
Old 08-09-2009, 10:55 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: cowl leak
says you cant remote link these pics.. please shrink em and post em here
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-09-2009, 01:06 PM   #5
LBJ
Re: cowl leak
I ran into some small rust when I was under the dash fixing the A/C-heater door controllers. I discovered that the water was coming in from the sheet metal seams under the leaf guard right in front of the windshield. There's a trough under there that lets you get to a few things and also lets water pass through to drain out at the bottm somewhere. For some reason, those weren't sealed properly at the factory I guess. No reason for them to start leaking since they are spot welded on assembly. I got some paste-form seam sealer and a putty knife and resealed all the way across best I could. I told the jackass painter to be sure and repaint over those seams and of course, he lied to me. Said he did but obviously did not. But, with the screen on, you cannot see down in there. Pizzed me off just the same.
LBJ is offline   Reply With Quote
