Rattle can hi-temp exhaust manifold paint?
I need to paint the exhaust manifolds (ram horns). The last Hi temp exhaust manifold paint I got did not dry completely until you ran the engine so it "melted" Until then it was a semi sticky powder.
Since it will be a while between paint and engine running with plenty of time to get the excess on everything else in the engine compartment is there a paint that drys but offers the heat resistance finish without the mess? How about toaster oven powder coating systems? Or regular engine paint and accept the fact that over time it will fade to the semi rust patina?? Thanks in advance.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Re: Rattle can hi-temp exhaust manifold paint?
Here dude...look no further...This stuff rocks!
http://www.eastwood.com/specialty-co...ting-1-pt.html
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
I had forgotten about that, I generally stay away from Eastwood stuff because it is expensive, but in this case you get what you pay for. Does it dry hard, not tacky? Thanks Patrick
I use the VHT brand header paint. You have to realize though that nothing short of a ceramic will last very long if it is driven regularly.
The VHT is available in cast iron tone also. I am using it on some headers now. Last edited by Houston54; 08-06-2009 at 02:59 PM. Reason: added color note |
![]() Join Date: Oct 2007
bbq grill paint 5 bucks a can satian black finish and half the price of the other stuff same temp rating too. i think 1200f.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) Last edited by 54 jimmy; 08-06-2009 at 05:10 PM. |
#6 | |
Thanks for all the responses.
Most of the rattlecan high temp can be treated in an oven if you have one large enough and can get the wife to look the other way long enough... it actually provides more even curing anyway... read the back of the can on duplicolor and vht
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
Cast Blast 1200 degree paint works well too. I have used it on a number of exhausts manifolds. It's a little cheaper around 10 bucks a can.
Thanks for the info..
Moderator
![]() Join Date: May 2007
POR 20 Hi Temp manifold paint. Have it on my daily driver for years. Still looks brand new. Brush it on, no mess.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Cantankerous Geezer
VHT is good paint. For any paint to stick the metal needs to be spotless. Glass bead or sand blasting, followed by a thorough wash.
Yukon Jack had the manifolds for his 69 powder coated a couple years ago. You might PM him and ask how it has held up.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
I sand blasted the manifolds and will clean off the residue. Local body paint place has the POR stuff, I'll look at that. Thanks
