Old 08-06-2009, 12:32 AM   #1
vegaschevy
removing body side molding clips
what is the easiest way to get these clips off the side? im trying to get all the clips off and get everything ready to get the sheet metal straight
vegaschevy is offline   Reply With Quote
Old 08-06-2009, 09:03 AM   #2
VanceH
Loving the Jimmster
VanceH's Avatar
Re: removing body side molding clips
great question my son is doing the same thing with his
VanceH is offline   Reply With Quote
Old 08-06-2009, 09:30 AM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
The clips have a nut on the back of them, similar to the nut on a emblem.
you could remove the nut and the clip will then fall off, I guess you could also grind the surface of the clip to remove it and push the remainder through the hole.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-06-2009, 09:36 AM   #4
UltraBlue71
UltraBlue71's Avatar
either way works fine, I'd try to save them as you'll need them later.. that is if you dont buy new trim kits
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 08-06-2009, 09:40 AM   #5
vegaschevy
nope, they are all going in the garbage!
Old 08-06-2009, 10:06 AM   #6
leddzepp
Moderator
leddzepp's Avatar
You need to take off your inner fenders to access the nuts to remove the clips on the front fenders. You need to remove the inside door panels to access the nuts on those.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-06-2009, 12:38 PM   #7
kevmic28
kevmic28's Avatar
I ground mine off. The bolts were rusted on the inside. I dont plan on putting the trim back.
kevmic28 is offline   Reply With Quote
Old 08-06-2009, 08:41 PM   #8
Dynomutt
Dynomutt's Avatar
I didn't have to take the door panel off on mine. They had a screw in the front, a nut in the back and stick on's in the middle.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 08-07-2009, 12:36 AM   #9
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
vegas, if you are going to just toss them and don't destroy them taking them off, I would be interested in them. Can't ever have enough little parts as spares. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
