Old 08-06-2009, 02:37 AM   #1
bj87gn
how to make 8 lug new chevy wheels fit on a c 20
The wheels fit fine but i was wondering where you guys buy the double(dual) threaded lug nuts to make the center caps attach to the whole mess and also how to get the wheel cap to fit down on the wheel in the rear correctly. do you use dually rear center caps or would you suggest buying a wheel spacer?
bj87gn is offline   Reply With Quote
Old 08-06-2009, 07:51 AM   #2
eagleuh1
eagleuh1's Avatar
Re: how to make 8 lug new chevy wheels fit on a c 20
I just bought some new used chromed steel wheels myself, haven't got to try them on yet. I'll keep an eye on your post though. Hopefully they'll work. These the same as what you got?
Much better looking than these old things.
eagleuh1 is offline   Reply With Quote
Old 08-06-2009, 07:53 AM   #3
paps69
Try eBay, that is where I got mine. You can get them from parts stores but they are high priced.
IF A FELLA DOESN'T USE HIS HEAD.......
HE MIGHT AS WELL HAVE TWO BUTTS
1969 C10 LWB "Granpaps Truck" (Project)
2000 K3500 Crew Cab LWB (Farm Truck)
2007 Chevy 1500 Crew Cab 5.3 (Daily Driver)
paps69 is offline   Reply With Quote
Old 08-06-2009, 10:20 PM   #4
bj87gn
yes those wheels are identical, i just need to figure out the center caps and the whole set up will look outstanding
Old 08-06-2009, 10:50 PM   #5
paps69
I was referring to the double threaded nuts. I didn't read far enough to see the cap issue. I used dually caps on the rear of my K20. It has a full time frontend so I used the dually caps up front so they match. I don't know how it would look with deep caps in the back and regular caps in the front. How much deeper do they need to be? Do you have any stud sticking out through the stock nut?
Old 08-06-2009, 10:57 PM   #6
BCOWANWHEELS
them are metric arnt they
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-07-2009, 01:15 AM   #7
sleepertruck72
sleepertruck72's Avatar
I used lugnutking on ebay for the lug nut conversions. There is a few vendors on ebay that sell them. They are 9/16" with the outer threaded portion for the center caps. I had to use the dually caps on my rear axle because the regular ones didnt fit. The dually caps are too deep but I cut off about 3/8" to make them fit. If you dont have the Dana 60 axle they should fit fine without having to use dually caps. Hope this helps.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 08-07-2009, 01:54 AM   #8
bj87gn
thank you very much. thats very very helpful
Old 08-07-2009, 09:40 AM   #9
eagleuh1
eagleuh1's Avatar
Are the lugnuts off the new Chevy Metric and the old standard. Crap if they are. I got everything with my wheels for $100. Maybe try a spacer to move wheel out.
Old 08-21-2009, 01:46 PM   #10
eagleuh1
eagleuh1's Avatar
I've got the DANA 60 rear in my 68 C20, what thread size lug nut should I order to make the conversion for the newer rims. Thanks, Jim.
Old 08-21-2009, 04:38 PM   #11
OhioDan
OhioDan's Avatar
I put a set of these on my 70 GMC. Had to put a 1 1/4" spacer on the rear so the centers would fit my Dana 60 hubs. Makes the rear wheels as far apart as the front wheels now. Looks good.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 08-21-2009, 05:04 PM   #12
Gumby'sC20
Gumby'sC20's Avatar
^ those look so good! Very understated and simple...but look so perfect on that truck
Gumby'sC20 is offline   Reply With Quote
Old 08-21-2009, 11:51 PM   #13
westofb
I really hate wet sanding!
westofb's Avatar
Here is a link (hope it works...lol) to lakeshore wheel...cheapest place I found to find the lug nuts you need...not sure which ones you need, so first link is 9/16"
http://www.lakeshorewheelandtire.com...2&prevstart=80
second is for 1/2"
third is for 7/16"
funny thing is they don't carry the plastic lug nuts that hold on the center caps!
westofb is offline   Reply With Quote
Old 08-21-2009, 11:53 PM   #14
Ben IV
Yes wheel studs on newer trucks are metric.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 08-22-2009, 09:20 AM   #15
eagleuh1
eagleuh1's Avatar
Thanks everyone. Ordered the 1/2 by 20 lugnuts from lugnutking on ebay. 32 for $42 delivered. This is on my 68 C20 with DANA 60. Sorry for hijacking thread, but the info was applicable here too. Guess i'll need to get spacer to make center cap fiton rear.
Old 08-22-2009, 03:27 PM   #16
sleepertruck72
You can use the spacer or buy center caps from a dually and use those. The only thing with those is they may not exactly match the front, and you have to cut about 3/8"-1'2" inch off of them. Personally I carry alot of crap most of the time in my truck, and I dont trust a spacer with heavy loads. Maybe I'm just a weirdo
72 C20 Longbed
05 1500 Z71
Old 08-22-2009, 10:08 PM   #17
eagleuh1
eagleuh1's Avatar
Thanks for the suggestions. I'll think about both choices. Jim
Old 08-26-2009, 08:31 AM   #18
eagleuh1
eagleuh1's Avatar
Got the lugnuts from lugnutking on e-bay. $42 bucks shipped. Looked to be good quality. Today putting on new tires and rims. thanks for the info everyone. Jim.
Old 08-26-2009, 02:10 PM   #19
kyfig70c20
OHDan- I just put the same wheels on my C20. I have the black plastic centers but I was wanting the beauty rings; did yours come with those or were they added-if so where did you get them? I have the big 'ol Dana sticking 6 inches out so I will probably look into the spacer. I won't be hauling thing heavier than my 250 pounds. The 16" E rated tires look like bicycle tires compared to the 9:50/16.5's I took off of it.
kyfig70c20 is offline   Reply With Quote
Old 08-28-2009, 04:30 PM   #20
OhioDan
OhioDan's Avatar
Thumbs up Re: how to make 8 lug new chevy wheels fit on a c 20
Mine came with the rims. Bought them off of ebay and the rims, rings, centers, and lugnuts all came as a package. Got them from Truck and RV Supply in Indiana. They're from one of those places that do the make overs from a standard truck to a custom coversion? Less the 10 miles on them when I got them.
