Hello All,
First, Thanks to all on the board. A cool community and very helpful. Well, I finally took the plunge and picked up a 1966 GMC 1000 SWB. All original, farm truck, really solid and straight, 250 stovebolt, oil bath filter, 8 leaf pack in rear, 1/2 rot bed, all interiors components work, missing radio (looking), all hubcaps present I was tired of looking at the gasser front end so I decided to lower it. I did a coil reduction by 1.5 coil. With help from archive board pages, I accomplished it with a spring compressor and unbolting the two u-bolts on the LCA. It was very simple and took me about two hours. I measured the coil with a cloth tape measure and put tick marks at every inch past one full coil and one at 25.5" (which is exactly 1 1/2 coil) from the bottom. After the drop the centerline of the front fenders is 28 3/4" off the ground. I am very pleased with the outcome. I will need to trim the bump-stops, but it does ride good. Thanks again and enjoy the pics. Just arrived: http://picasaweb.google.com/shadmeier/GMC10TRUCK# |
Re: NewB-GMC1000-SWB-FrontSpringReduction-RAKE
more pics
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
1962 C-10
Looks good!! Welcome to our sickness..
![]() Very nice looking Jimmy you got there... Good luck with her and keep us posted...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
** update.
The turbo is running good. I installed a crankcase evac. system to help with blow by caused by boost. Gloss blacked the steelies. Installed drop shackles out back to get it down 1.25". ![]()
BLAZER THIRTY!!
![]() Join Date: May 2007
COOL TRUCK!!! love the 60-66gmc's, here is my 62 torsion bars turned down and jeep coil's in the rear dropped the rear about 5 inch's, i didn't measure the front before i did it but i love the stance!!
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner ![]() ![]() ![]() 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B Last edited by Matt's k5; 08-15-2010 at 12:44 PM. |
Matt, thanks man. How does that V6 pull? gotta love those GMC's
BLAZER THIRTY!!
like a horse!!, still runnin strong fires up first crank, does not blow or leak any oil, love these engines so differant i had so many people think it was a big block 409 they didnt belive it until i made them count the plug wires
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner ![]() ![]() ![]() 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
BLAZER THIRTY!!
Hollister, CA.
![]() Join Date: Sep 2006
Truck looks sharp man ...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Looking good!!!
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 |
Hay Matt's k5 I really like that photo of your truck. Something about it just pops. I rotated it a little bit because it looked a little crooked but still a really good photo.
I wanted to drop the front end another inch, so I popped the springs out and cut 3.5" (following the spring coil) off.
I originally cut 1 1/2 coil off them. So total is right under 1 3/4 coil. Here JED is: ![]()
#13 |
![]() Join Date: Sep 2009
what have you done to the back end?i have a 64 gimmy and i took all short springs off and got long shackles from ece. 3 long springs . about 4-5 inch drop
#14 | |
(( UPDATE )) -GMC1000-JED -SWB-FrontSpringReduction-RAKE
At first, if I remember right, I removed every other leaf which totaled 5. 8 to start minus 5. Then I put shackles on it on the highest hole (most drop), then went back an removed the shortest leaf. I am now with just two leafs and what is where it sit today. I did a measurement at the center of each fender well to ground. Front is about 26 1/4" and Rear is about 24". I hope this helps
#15 |
i just measured mine and it is exactaly the same. as low as the back will be unless you go with a flip kit. but i am not that big of a hurry to spend another $150. kind of like the rake look.
#16 |
gimmy64, im with ya. Next would be a flip kit or notch the frame. I'll pass.
#17 |
![]() Join Date: Jul 2011
Dude Jed's looking good. I like your mini-rake. Makes it look mean. Mine is now level after my C-notch but now i wanna drop an inch up front to bring just a little rake back.
