Old 08-06-2009, 09:34 PM   #1
69_C10
Doing it my damn self.....
69_C10's Avatar
Suspension question...
Hey guys, I'm building my suspension and have a couple of quick questions...
1) I'm simply using the drop coild to give my C10 the stance I want. 5" in the back and 2 1/2 in the front. What size springs should I buy for the front?
2) What size shocks for the front and rear?
Thanks guys,
Have a great day!
Mark...
Project 69 Stepside...http://67-72chevytrucks.com/vboard/s...d.php?t=290761
69 C10 Stepper - Current Build
94 Silverado - Driver
05 Hummer H2 - Unique Whip
69_C10 is offline   Reply With Quote
Old 08-06-2009, 10:09 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Suspension question...
i dont THINK you can get a 2.5" drop SPRING you can get a spindle....you could go 2" 5" or they MIGHT make a 3" front drop spring......get pics im interested in how much drop it give..(pic wise)
John
1999 Toyota Tacoma 4x4
Old 08-07-2009, 06:23 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can get three inch front springs. I always use the Summit brand springs, part number SUM-G727. When you get them and open the box, you will find they are Ground Force brand that Summit reboxes and sells as their own store brand.
Old 08-07-2009, 01:07 PM   #4
69_C10
69_C10's Avatar
[QUOTE=Tx Firefighter;3451603]You can get three inch front springs. I always use the Summit brand springs, part number SUM-G727. When you get them and open the box, you will find they are Ground Force brand that Summit reboxes and sells as their own store brand.[/QUOTE
Tx Firefighter, thats a good tip on the Summit Shocks. I'll be placing my order there for shocks. Thanks. Love the build thread
Mark...
Old 08-07-2009, 01:15 PM   #5
cdowns
cdowns's Avatar
you'll need shorter shocxcks in the rear plus a shock relocation kit and of coursae the adjustable panhard bar so you can center the rear end
Old 08-07-2009, 01:40 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Look no further than Early Classic Enterprises (ECE), as they will have everything you will need.
Check out my build thread in my signature for the install of a 4.5/6" ECE drop kit.
One thing you will need to consider.... if you are wanting a 2.5" drop in the front and decide to use a spindle, you will need to upgrade to disc brakes. Don't worry though, as this is covered in my build thread as well.
Just click on Blank Slate, and let me know if you have any questions.
Also, once you get the kit on, you will always want to go lower.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-07-2009, 02:05 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you get the dropped spindles from ECE, or just about any other supplier, you'll be doing a conversion to disc brakes. W/O doing that conversion, then lowering springs are your option. As far as ECE is concerned, you can get another inch of lowering by using their one-lower spring with their spindles, for a total of 3.5 inches. 5 inches in the rear will look good, too. You gotta watch going too low in the rear because of interference between the drive shaft and the crossmember that the rear trailing arms attach to. You can get another crossmember, and ECE has those, too.
Member Nr. 2770
Old 08-07-2009, 02:11 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
ChevLoRay is correct. I wouldn't go any lower than a 6" spring for a daily driver.
As far as the shocks, ECE offers a KYB gas shock which provides an excellent ride.
-Nate
Old 08-07-2009, 02:26 PM   #9
jbristo67
resident oilfield trash
jbristo67's Avatar
I have 2.5 front springs they are western chassis from sport truck direct
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
