Old 08-07-2009, 02:23 PM   #1
Vernski
pic's of power steering set up's
Does anyone have any pic's of power steering set up's for a 230 L6. My truck is a 65 GMC but Chevy's are the same so if you have some could you please post them? I used the search but came up empty. Thanks Vernski
Vernski is offline   Reply With Quote
Old 08-07-2009, 03:47 PM   #2
bubba327
HOW long until spring??
bubba327's Avatar
Re: pic's of power steering set up's
I just found a bracket on E-bay but do not have it installed yet. I think there might be a missing piece and could use pictures also. I am glad somebody else is gonna stay with the I-6!! I looked all over for this bracket, finally found it off a 70 Camaro.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 08-07-2009, 03:49 PM   #3
bubba327
bubba327's Avatar
Hey Vernski-- welcome from Southern Idaho
Old 08-07-2009, 07:36 PM   #4
Vernski
Hi Bubba thanks for the heads up and welcome. Well I bought a set of bracket and braces off ebay also and when I went to put them on nothing will fit. Well I got leperconned as in bend over buddy,[no offence if your Irish] but they were advertized as fitting a 230 L6. I hope you faired better than i did on ebay. Well I just needed some pic's to see if I'm headed in the right direction. I'm going to fab my own bracket if I can get an idea where they bolt up on a 230. That said I hope we can get some pic's to see how it should be. By the way where is Star at in Idaho I'm 8mi nw of CDA Thanks Vernski
Old 08-07-2009, 09:37 PM   #5
xratt
xratt's Avatar
great thread, now we need some pics. I'm starting this project on my 1966 C10, except i have a 305 sb. So I have to go junk yard hooping tomarrow to try and find my brackets. I have a 1986 power steering box and drag link. I'm hoping this will come close to fitting on my 1966 frame. I find find out more tomarrow.
1966 C10, SB305, bagged.
1955 VW Buggy, 2.0L
1978 Honda CB550
http://67-72chevytrucks.com/vboard/s...9&goto=newpost
xratt is offline   Reply With Quote
Old 08-07-2009, 11:54 PM   #6
bubba327
bubba327's Avatar
Between Eagle and Middleton, over the hill from Emmett
I have the correct bracket off a 250 I-6 camaro. It has been cut a little for header clearance. (No trouble to weld a piece back in) I found a E-Bay seller 's listing for the headers and sent a pm to him asking about the bracket and scored. I had been looking on the chevelle forums, nova -forums, H.A.M.B. the inliners etc (After looking here on the 60-66 boards first) Nothing in the local junk yards. Beginning to think I might have to fab my own. Planning on using a nova pump. I can send a pic tomorrow if you need.
Old 08-08-2009, 12:16 AM   #7
Captainfab
60-66 Nut
Here are a couple of setups right here in the classifieds......I think they are both still available.....one for each of you
http://www.67-72chevytrucks.com/vboa...d.php?t=355548
Old 08-08-2009, 12:16 AM   #8
Vernski
Hi Bubba yeah if you could post a pic of your bracket that would be great. I have mine drawn out but that's subject to change when or if I see something better thanks,---Vernski
Old 08-08-2009, 01:18 AM   #9
Vernski
Hey thanks John for the link, my bracket's look kinda like the one's on the left but the one I need is like the very bottom one on the right. I think I'm on the right track just need some pic's of the bracket and the rest of the set-up. Vernski:gmc2
Old 08-08-2009, 10:41 AM   #10
Vernski
Hey Bubba I found this link check it out.Vernski http://67-72chevytrucks.com/vboard/s....php?p=3430543
Old 08-08-2009, 10:45 AM   #11
Corts60
Just here to tinker
Corts60's Avatar
Here is the power steering set-up on my '60:
Old 08-08-2009, 11:00 AM   #12
Vernski
???---Vernski Yeah I get it now Jolly Joker "Funny"
Old 08-08-2009, 11:42 PM   #13
Captainfab
60-66 Nut
Those bolt on pulleys look like the ones for a small block with a short water pump. Which balancer do you guys have?
Old 08-09-2009, 02:12 AM   #14
Vernski
Hi John my balancer is a single pulley and has bolt holes I for either a pulley puller or I guess you could bolt another pulley to it. I have no idea what the norm is for these engines but it is a 230.---Vernski
Old 08-09-2009, 10:55 PM   #15
bubba327
bubba327's Avatar
I already have a double pulley set up on both crank and water pump . Hoped to get to the pump today but worked on the tilt column instead.
Old 08-10-2009, 12:35 AM   #16
Captainfab
60-66 Nut
So does your balancer have the pulley built in or is it seperate?
Attachment 486221
Looks like you're part way there already Bruce.
Old 08-10-2009, 10:55 AM   #17
Vernski
[QUOTE=Captainfab;3456234]So does your balancer have the pulley built in or is it seperate?
It looks like it's one piece, so I assume you can bolt another pulley to it? Or do I have to get another one? Also where can I find either? Thanks---Vernski
Old 08-10-2009, 11:42 PM   #18
Captainfab
60-66 Nut
[quote=Vernski;3456741]
If it is the same crank pulley as a small block with a short water pump, I have a couple. I don't have anything for the water pump pulley though.
Old 08-11-2009, 12:12 AM   #19
Vernski
[quote=Captainfab;3458038]
Thanks John that's one step closer will give you a call when I can pick one up, I hope it fits my luck has not been good lately on things fitting well. On another note did you get those instructions on the adapter plate formatted yet? if not is it possible to print them out somehow and I could pick them up? Just a thought thanks Cap.---Vern
Old 08-11-2009, 12:55 AM   #20
Captainfab
60-66 Nut
[quote=Vernski;3458103]
Yeah printing them is no problem. I haven't had time to figure out how to reduce the file size to email them.....I'm not quite that computer savy yet. I'll print another set right now.
Old 08-13-2009, 03:32 PM   #21
Vernski
http://67-72chevytrucks.com/vboard/s....php?p=3431900
Here is another thread of pic's and stuff. Vernski
