Old 08-07-2009, 03:18 PM   #1
tymer
72 Chevy big block motor mount Header problems
Hello. My recent project is a 72 Chevy C10 LWB 2 wheel drive. I pulled the mostly disconnected 350 out in favor of a 75 4 bolt 454. I got the motor and trans all bolted in and most electrical hooked up then proceeded to install my passenger side header from Summit and then moved on to my driver side which of course wouldn't fit because it hits the frame part of the motor mount. After doing some research it appears I need to have the big block style motor and frame mount for these headers to work. Does anyone have a different idea that has worked for them? or does anyone have a motor mount setup for a big block 72 for sale? My project is basically at a stand still so any friendly advice would be appreciated...Thanks very much.
tymer is offline   Reply With Quote
Old 08-07-2009, 03:40 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: 72 Chevy big block motor mount Header problems
they come up fairly often on the part board, maybe you can scan over there and luck out. Also, the search function on the site rocks, so you may try that to find some solutions. HTH
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 08-07-2009, 04:30 PM   #3
jthornton
jthornton's Avatar
i have a 72 and i put an 86 454 in it and my headers wouldnt fit so we put motor mounts from an 80's pick up and bolted it to the frame rails then just welded the bottom of the mounts to the cross member.. its been workin out for me so far
jthornton is offline   Reply With Quote
Old 08-07-2009, 04:31 PM   #4
70rs/ss
70rs/ss's Avatar
You can also use the 73 and up SBC mounts as well, they are very similar to the 72 only BBC mounts.
70rs/ss is offline   Reply With Quote
Old 08-07-2009, 05:05 PM   #5
Dynomutt
Dynomutt's Avatar
If or when you buy stock mounts pay VERY close attention to what you are getting. A lot of these mounts look similar until you compare side by side or try to fit them in place. Ask me how I know. I have a real nice set of P-series mounts I'll sell ya. JK. I would never pass them off to someone that didn't want P-series mounts. Good Luck.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 08-07-2009, 06:27 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Look at this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=122645
Also,... The FAQ section has a ton of useful info!
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=262550
Keith
Convert to disc brakes.
Old 08-26-2009, 03:37 AM   #7
tymer
Thanks to all who helped. What I ended up doing was getting some tubular motor/frame mounts that were from Performanceonline. These sell brand new for $130.00+ shipping for the frame and motor mounts and bolts. That's pretty close to what most of the used BB mounts are priced for here and elsewhere when you can find them. The headers from Summit for the 72 C10 2wd fit just fine with no issues. The mounts bolt up with no drilling required, the only thing I had to do was unbolt the brake lines where they are secured on the cross member so the mounts could slide under them. They also raise the front of the engine approx. 1/2 inch higher than it sat with the small block mounts. The water pump setup I have is the long one and it is close to the radiator. I used the original fan spacer which is about 1 inch thick and a flex fan which gives me about an inch or so of clearance between the fan and radiator. I should also note that my radiator is the heavy duty thick one. I used the stock transmission cross member with my TH-350. Thanks again. Here is the address that will take you right to the mounts: http://www.performanceonline.com/sto...cat=455&page=1
Old 10-25-2009, 02:54 PM   #8
lovnthe70
lovnthe70's Avatar
what did you use for a fan? i just did this swap with those same mounts and only have 2 inches between water pump and radiator so im stuck until i can find a fan that works!! thanks!
1970 GMC- 454
DONT GIVE ME NO JIBBA JABBA!!!
lovnthe70 is offline   Reply With Quote
Old 10-25-2009, 04:50 PM   #9
tymer
I used a Hayden flex fan part# 3569 from Oreilly auto parts with the stock 1 inch spacer that was on my 350. I have had no cooling problems at all. Good luck with yours...
Old 10-25-2009, 05:28 PM   #10
lovnthe70
lovnthe70's Avatar
thanks!! ill give that a try!!
1970 GMC- 454
