08-07-2009, 03:29 PM | #1 |
Assembly Help
Some time ago I removed the water pump from my 66 250/6 and while pulling the fan out carefully I dropped all the parts onto the ground below me. Now is the time to replace pump ,pulley, extension, and fan. My problem is that with all those parts there is a round plate that is cupped on the oter edge with 4 hole to match up with the fan. My question is where does this disc belong? under the pulley? Can any one help me out?................Kirby
08-07-2009, 04:46 PM | #2 |
Re: Assembly Help
Sounds like a fan spacer to me but cant be sure. Someone will chime in who knows exactly what it is. Pictures are helpful in these stressful times......
08-07-2009, 10:24 PM | #3 |
Re: Assembly Help
Yep............I believe you are talking about a spacer.................It goes between the water pump and the pulley to linr up with the other pulleys.........Hemmit
08-08-2009, 02:00 PM | #4 |
Re: Assembly Help
Thanks alot Hemmit , did'nt want to take it apart again.........Cheers.....Kirby
