Old 08-07-2009, 06:26 PM   #1
threeonthetree
threeonthetree's Avatar
how does a 4 speed run behind a 250
thinking about picking up this truck it has a six with a standard trans
and a smooth column the guy doesn't want much for it and i was thinking about getting it
but does anyone have a 250 with a 4speed behind it how does it run?
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 08-07-2009, 06:34 PM   #2
lilred67
lilred67's Avatar
Re: how does a 4 speed run behind a 250
my '67 had a six cylinder/4 speed. i liked it. still have the 4 speed but upgraded the motor to a 350.. some of these trucks came from the factory 6 cyl./4 speed.
lilred67 is offline   Reply With Quote
Old 08-07-2009, 06:36 PM   #3
Ackattack
Ackattack's Avatar
don't know why it would really matter if it was a 3 or 4 speed, the top gear is going to be 1:1 either way. Just no stupid column shifter.
Ackattack is offline   Reply With Quote
Old 08-07-2009, 06:38 PM   #4
threeonthetree
will i have to mod the floor to get the four speed in there?
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 08-07-2009, 07:14 PM   #5
sharpmark
my 69 has 250/4spd and 4.11 diff gears and i drive it to work everyday and i'm happy with it.never use first gear and will probably change the diff gears soon to keep the revs down abit.did a 450 mile trip in it a few weekends ago and found the petrol mileage was similar to the same trip in my 69 350/2spd auto pontiac lemans convert.have decided to keep the truck i6 cause everybody else over here puts a v8 in them and this truck is cool as it is.have a clifford inlet manifold and 350 holley to put on it and will make my own headers and dual exhaust.
sharpmark is offline   Reply With Quote
Old 08-08-2009, 07:23 AM   #6
68Stepbed
68Stepbed's Avatar
Is it a bulldog 4spd or a regukar 4spd? In a bulldog, 2nd,3rd,and 4th are the same ratios as 1st,2nd and 3rd in a 3spd. 1st gear is just very low for pulling and mostly used for a really slow moving speed for farm use.
If it's a regular 4spd, like a Muncie or Saginaw, I would say to get it. The final drive gear is still 1:1 like the 3spd, but with closer gear splits.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-08-2009, 09:34 AM   #7
Elephanthead
Inline 6s are inherently balanced. It is probably the best cylinder arrangement you can have in an engine. It makes plenty of power, if that is your concern. I love inline 6s, I am collecting a car of each type, I have a 292 chevy, 4.0 jeep, I need toyota, a bmw and a ford.
Elephanthead is offline   Reply With Quote
Old 08-08-2009, 10:32 AM   #8
Ackattack
Ackattack's Avatar
Don't forget the newer 4.2 vortecs in the trailblazers
Old 08-08-2009, 03:52 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You're gonna need a high hump for a truck 4 speed.
Old 08-08-2009, 04:00 PM   #10
turp mcspray
turp mcspray's Avatar
If you're gonna have a 6, I think a 4 speed is the only way to go. I had a 69 4x4 once with a 292 4spd. I think the 6 needs all the help it can get. Mine got crappy milage and NO power to boot. I can't imagine anyone wanting a 6 but to each his own. No offense to all the 6 lovers out there!!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 04-09-2010, 09:29 AM   #11
culp7
HickTown
culp7's Avatar
i have a 250/4speed in my 68, and mine gets around 15 MPG in town/highway driving and has plenty of power for a six
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 04-09-2010, 12:47 PM   #12
slomotion
Old Duffer
slomotion's Avatar
I have to jump in here...I'm running a 292 4bbl with a WC T5 and love it. Plenty of torque, good gear ratios, and reasonable mileage for the weight of the truck. I don't agree that the I6's have "no power", I have all the power I need for the truck's intended purpose.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 04-09-2010, 01:10 PM   #13
Keith Seymore
Keith Seymore's Avatar
We've had a couple and they're great.
Incidently, our '69 GMC would routinely outrun a fella at work who had a V8 truck: 292 L6 punched to 305, true duals, 3x2 Rochesters with a Pontiac progressive linkage, Hurst shifted 3.11 low gear Saginaw 4 speed with 3.73 gears...
Just about every time he'd make a tweak, we'd make a comparable change and run 'em off. He never did beat us across the intersection - which frustrated him to no end cause he knew ours was a 6.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-09-2010, 05:02 PM   #14
Shaky
Six in a row makes it go...
Shaky's Avatar
I have a 250 with a Richmond 5-speed behind it and another truck with a 292 and SM420 4-speed. I like 'em.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-09-2010, 05:31 PM   #15
NicoSlam
I'm running an I6 with a 4speed overdrive. I love the pur they make at 600rpm's
NicoSlam is offline   Reply With Quote
Old 04-09-2010, 10:48 PM   #16
kyull67
kyull67's Avatar
I run the 250 with the four on the floor. Check my build thread for more info, I would bet money it out runs most 350's out there. I love it!
kyull67 is offline   Reply With Quote
Old 04-10-2010, 07:56 AM   #17
Shyguy
Junior Member
Shyguy's Avatar
My old '67 swb has a stock 4 speed behind a '70 i-6.
It is not running great, carb problem I think, but it will make the rear tires spin it I want when taking off. I am not sure of the rear end gearing though since I have never taken the cover off and checked, probably 3.73.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-10-2010, 08:18 AM   #18
LMN8UR
LMN8UR's Avatar
Don't forget the 3 speed overdrives! The NP833 (MY6 code) from the 80's is a direct replacement for the Saginaw 3 speed. You get a 3.09 first gear and 0.76 overdrive (fourth). Best move I've done with mine.
You will need to cut a hole for the shifter of course.
Good Luck.
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
