???? about POR 15 Hardnose Paints
I am considering using the POR 15 Hardnose series paint on my stock steel wheels. Has anyone used this product and what are your thoughts- ie how does it hold up go down etc. Thanks Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Re: ???? about POR 15 Hardnose Paints
The POR holds up great but for any exposure to sunlight you must use the clear coat or it will fade out and dull.
67 GMC SW 383 stroker/TH350 w/ 4.56 gears - under construction 04 GMC 1/2ton daily 07 GMC Acadia wifes daily ![]() |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Harold, for what it's worth, I have used hardnose chevy orange paint on an engine block, it holds up well, but I think any tractor supply paint that is for farming equipment holds up pretty close and is pretty cheap. I usually spray it on frames now as I am a believer in it. I think I am going to use it over some etching primer when I paint my 15 x 8 steelies. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
