The best lowering springs for the money?
Who has them? Anyone had good or bad luck out there? I am going to take out the poorly chopped up ones the PO did and put in a 3/5.
'67 C-10 Shorty - 454, 5spd, and speed holes! |
Re: The best lowering springs for the money?
Early Classics in my truck and so far very smooth....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
im thinking about doing a drop kit on my truck also
i was looking around cpp seems like they have good drop springs and kits and they seem to be the cheapest around. i was going to do a 3/5 drop but only buying the rear springs and cutting the front ones
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
I went with the 4/6 kit super happy with it....
U need lower shocks and ajustable trac bar
Mike
I replaced the spindles, rear shock relocators, panhard bar, four shocks and springs.
Thanks Al, I want to lower mine but I don't want to get in over my head.
I'm not as good as I once was, But I'm as good once as I ever was. |
resident oilfield trash
Did you notch your frame
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
it makes sence with the front suspension apart to replace ball joints tierod ends and other parts with 40years of wear on them so you get the best possible ride with little to no slop
#12 | |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#13 |
Not yet,,,I might in the future because it is close maybe two inches betweent the frame and the diff.
One more thing I agree with cdowns as I changed EVERYTHING while in the front new ball joints, new tie rods inner and outers, new calipers, hoses, wheel bearings inners and outers. In the rear I also added the shock relocators...
#14 |
some pictures of the build could be seen here:
http://67-72chevytrucks.com/vboard/s...15#post3434315
#15 |
![]() Join Date: Jan 2009
sharp ride there big al. i got all the replacement parts for my front except the a-arm shafts. did you replace these also? just wondering if i need to pick some of these up before i start.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
#16 |
I had replaced mine last year when I re-did the truck so I would suggest to get new ones..
#17 |
I did a 3.5/5 on my truck with stuff from ECE. ECE stuff may be a tad pricier than CPP, but they make up for it in customer support and overall knowledge. ECE specializes in 63-72 suspension whereas CPP makes stuff for everything. I've got no complaints with anything from ECE or their customer service. I've bought stuff from CPP before, and when I called back about an issue, they didn't have much advice and weren't very helpful.
My suspension components are as listed: FRONT -2.5" drop spindles -1" drop springs -KYB shocks REAR -5" drop springs -shock relocater kit -Super Track bar kit -KYB shocks I didn't notch the rear nor do I need to. I have plenty of clearance even with stock bumpstops. ![]()
#18 |
That's a nice stepper right there!
