Old 08-07-2009, 08:23 PM   #1
davebloomer
davebloomer's Avatar
gas tank neck grommet?
Can you change it without pulling the tank?
Also is there a difference in the grommet from 67-68 and 69-72?
davebloomer is offline   Reply With Quote
Old 08-07-2009, 09:12 PM   #2
big_al_71
big_al_71's Avatar
Re: gas tank neck grommet?
yes you can, use plenty of silicone as it is a PIA...Ask me how I know...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-07-2009, 10:02 PM   #3
71big block
1971 GMC 3/4 ton, 572 CID
71big block's Avatar
There are 2 different gaskets but I don't know the year applications, check the LMC website
71 GMC 3/4 572 CID,
1988 GMC 1/2
2006 Saturn Vue
"We always have parts left over on a job this size"
71big block is offline   Reply With Quote
Old 08-08-2009, 10:44 AM   #4
68gmsee
Active Member
68gmsee's Avatar
I've done it a couple of times. The first time I did from the outside in with a wooden dowl slightly chisel shaped and smoothed. As mentioned by big-al, use lots of silicone lubricant or other lubricant that won't damage your paint.
Last year I replace the one on my 68 GMC and I did it a different way. I pushed it all the way through first and then installed it outwards from the inside. I used Armorall spray as a lubricant cause that's all I had at the time. Seem to work pretty good.
68gmsee is offline   Reply With Quote
