72 lwb frame for sale
Really solid lwb leaf spring frame on wheels for sale, $150.
Front disc brake setup is complete with good rotors and good backing plates. (Right lower "A" arm is damaged but a good replacement is included). Frame has the original stick shift cross member but an automatic crossmember is included. Rear end has 3:07 gears. ( PO tried to weld the perches to the lower spring leaf). Left rear cab mount is missing. The steering box and linkage is intact and is in good condition. Frame horns appear to be out of line slightly. The frame has a lot of really good parts on it and if no one wants the whole assembly then it will be parted out. I can post other pics if desired. Frame is located in Muskegon, MI. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: 72 lwb frame for sale
Ttt
Ttt
Ttt
