08-08-2009, 08:34 AM | #1 |
Back from the blaster
Now the real fun begins! I'm glad I had this cab blasted, it turned out nice I think. Next up...cab corners, rockers, flooring & supports!
08-08-2009, 08:35 AM | #2 |
Re: Back from the blaster
A few more...
08-08-2009, 08:55 AM | #3 |
Active Member
Looks clean... Can you give us an idea on cost and media used?
I'm planning on doing the bed on my 69 this year and probably the cab next year. I'm sure you don't have a rust problem in Utah like we do in other areas, but what did you use to protect the cab after the blasting? |
08-08-2009, 09:04 AM | #4 |
It cost me $700 to have the inside and outside blasted, and primered. I'll have to get back to you on the media type (I think it was called green diamond...or something like that). He sprayed some R/M Epoxy Primer on it when it was done so it wouldn't start rusting on my way home I'm going to be taking the bed over, but I'm going to have him soda blast that. The nice part about the soda blast is that it does not generate the heat like sand and other more harsh media does, nor does it pit the metal. The downside to that is that it will not take any rust off. Lucky for me, my bed is in fairly decent shape.
08-08-2009, 09:07 AM | #5 |
Yup...Green Diamond Abrasives
08-08-2009, 09:12 AM | #6 |
700 I got the cab and all the bedparts priced to blast and prime for 250.00 maybe its just your area you livein but 700 seems rather high for just the cab but it does look good
08-08-2009, 09:19 AM | #7 |
I don't think you could get a fender done in this area for 250 I have seen a few posts on here for what people paid, and I've seen anywhere from 200 to 1000, so I feel pretty good about it. The other part of the price equation is that I trust this guy to do a good job, and good jobs aren't necessarily the cheapest.
08-08-2009, 09:55 AM | #8 |
the cab looks really good, and the price is right because that is how much it would cost here in my part of the country.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-08-2009, 10:04 AM | #9 |
looks good, and you got some rust repair to do.....price seems just about normal, and fair
08-08-2009, 10:14 AM | #10 |
69 K20
$700 for just a bare cab seems a little high to me. I don't want to rock the boat here, but I am in the Chicago area where nothing is cheap, and I found a guy to soda blast the entire body for $1000. He said he would blast the frame and suspension for $500 and an extra $200 to powdercoat.
08-08-2009, 10:24 AM | #11 |
Active Member
Thanx for the addtional info.
I've been told that I could have the bed done for around $300 here in my area but I haven't done any actual shop pricing though. I guess it depends on the whether you are in an economically depressed area or not. If the shop needs the work, they may be willing to do it cheaper. |
08-08-2009, 10:27 AM | #12 |
Never Ending Projects
I would highly recommend you do a lot more research on soda blasting. It works well BUT it can have some major impact on your painting. Most paint companies will not warranty their paint if the part has been soda blasted. It ends up leaving a resude that is almost impossible to get 100% removed and will cause adhesion problems with the paint.
It has been talked about in depth on a number of paint/car boards. Good luck.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-08-2009, 10:29 AM | #13 |
Luckily I'm not in a boat
There were two things that cost me more on this one 1 I wanted it done inside and out, and I wanted it primered. We also upgraded the epoxy (well, according to the blaster) which was $200 in his cost, so again. I don't feel bad about that. |
08-08-2009, 10:33 AM | #14 | |
08-08-2009, 10:43 AM | #15 |
I would stay away from the Soda blasting, It will cause corrosion which is bad,
As far as price..I have had a few experieces with the 250.00 guys and the 700.00 guys, It is just like paint, if you go to Earl Schieb or Maaco, you get an Earl Schieb Paint Job....You always get what you pay for in life. If they are any good you will pay for it. JMOpinion
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
08-08-2009, 10:50 AM | #16 |
soda doesnt do a thing to rust and there are far ranging rot issues if not absolutly cleaned up in the crack a crevises //it rits metal like pouring battery acid on it
theres a reason why most paint manufacturers wont warrenty thier paint thats applied over a soda blasted finish with a good blaster operator the heat warping is a nonissue far blown out of proportion as an old wives tale
08-08-2009, 10:56 AM | #17 |
where did you get yours blasted? i need to get mine done and thats alot cheaper than the quotes i got
69 burb/01 yukon chassis 65 Comet Caliente 289 4 Door Sedan 99 Millenia S (supercharged) 4 Door Sedan 02 Yamaha R6 69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136 building with a buddy: 85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194 |
08-08-2009, 11:02 AM | #18 |
Here are couple links to help you research.
http://www.hotrodders.com/forum/once...ng-162700.html http://www.hotrodders.com/forum/has-...=soda+blasting
08-08-2009, 11:02 AM | #19 | |
08-08-2009, 11:40 PM | #20 |
If you follow the directions correctly, use the epoxy primer as the manufacture of soda blasting equipment you won't have issues. If you don't use epoxy primer after soda blasting the paint will not stay. If not immediately obvious, a pressure hose at the car wash will peel it right off. A 68 grill I seen wasn't treated with epoxy primer done that. Re-blasted coated with epoxy primer, no more issues 2 years now.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
08-09-2009, 07:26 AM | #21 | |
and yes the guy that is going to be painting mine said t be sure that no one soda blasted the body panels because of adhesion problems lclippard I sent you a pm |
