Old 08-08-2009, 12:21 PM   #1
68Stepbed
68Stepbed's Avatar
Anyone using Hotchkis swaybars?
I'm really interested in making my truck handle better. I know it's still a truck and it will never really handle like a sports car, but it would fun to give them a good run on an autocross or on the dragon. Hotchkis has some pretty trick swaybar setups that seem to look better designed than the factory style stuff. Their rear bar looks much better than most aftermarket bars. The only thing I'm worried about is the rear bar may interfere with my ECE Super Track bar since it mounts by the trailing arm instead of the top of the gear housing.
Has anyone got one? Care to elaborate?
Linkamajig
Install instructions
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-08-2009, 01:19 PM   #2
big_al_71
big_al_71's Avatar
Re: Anyone using Hotchkis swaybars?
I dont have Hotchkis but I have the ones from CPP, since I replaced my rear trailing arms for the tubular one I had to take my rear sway bar off as it is not needed. With the sway bars from CPP it was 100% better specially at high speed ripping thru turns..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
