Old 08-08-2009, 01:23 PM   #1
oneoutrage
AD vs EZ SWAP
I have a 52 5window and just got a 92 s10 single cab long bed to swap. Who makes the better kit ad or ez - why?
oneoutrage is offline   Reply With Quote
Old 08-08-2009, 04:16 PM   #2
54 jimmy
54 jimmy's Avatar
Re: AD vs EZ SWAP
go with the ez kit it includes everything. the ad kit comes out to be more after you buy everything else to go with the kit. the ez kit uses verything possible off the s10 to save you some more dough in the long run. i have the ad kit and would go with the ez kit if i had to do it all over again.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 08-08-2009, 04:18 PM   #3
oneoutrage
Re: AD vs EZ SWAP
Thank you sir
Old 08-10-2009, 05:35 PM   #4
1950 GMC
1950 GMC's Avatar
Re: AD vs EZ SWAP
So with the AD kit what extra parts do you need to purchase besides the tranny crossmember?
Thanks,
Garrett
My 1950 GMC Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=351867
My 1950 GMC Photobucket Account:
http://s565.photobucket.com/albums/ss95/1950GMC/
1950 GMC is offline   Reply With Quote
Old 08-10-2009, 05:59 PM   #5
54 jimmy
54 jimmy's Avatar
Re: AD vs EZ SWAP
motor mounts, steering linkage depending on the column u use,lower rad replacement brace,hardware, find a brake pedal and bracket, do i need to go on. i had to fab or scrounge a lot to get the other stuff i needed. i modified the s10 wiring to work in my truck to save some money. the ez kit is worth the price it is well enginered and i talked with the owner and he is very nice and know his stuff. an will help you with any questions you have. just go on the two sites and look at the two kits and decide for yourself.
www.e-zchassisswaps.com
www.ad-engineering.com
i not knocking the ad kit it is good if you don't want to use all the stuff of your doner s10 that you can,but it is up to you the builder to decide the best route. like i said befor if i had to do it over again i would go with the ez kit. thats just me though.
Old 08-10-2009, 08:39 PM   #6
britnjc
britnjc's Avatar
Re: AD vs EZ SWAP
I used the AD kit and found it very easy and I used everything from the s10. I used the booster and brake pedal mounting bracket from the s10. If you have any mechanical skills you can make the s10 stuff work. I also used the wiring from the s10 and computer. I didnt even move my engine since i had a nice running 4.3 liter in it. I also like the design of the ad kit better by reading both the sites. I looked at both before I purchased and the AD kit in 600 to 700 cheaper now if I remember. The kit would be simple to make also if you look up some of the swaps on here you can get dimensions for the brackets and send them you a local machine shop and come out even cheaper. my 2 cents
britnjc is offline   Reply With Quote
Old 08-15-2009, 06:24 PM   #7
50Bow-tied GMC
Re: AD vs EZ SWAP
Britnjc, When you got your kit how was AD to work with?
Tyler
50Bow-tied GMC is offline   Reply With Quote
Old 08-15-2009, 09:34 PM   #8
britnjc
britnjc's Avatar
Re: AD vs EZ SWAP
Well their kit was so straight forward I really didnt need to talk to them but I did one time and asked about radiator options and they were very helpfull
Old 08-16-2009, 10:19 PM   #9
55dude
55dude's Avatar
Re: AD vs EZ SWAP
why buy a kit at all? the people i talked to were sure having buyers remorse. there is so much info floating around about AD to s10 swap you could make the brackets yourself.
55dude is offline   Reply With Quote
Old 08-17-2009, 09:08 AM   #10
britnjc
britnjc's Avatar
Re: AD vs EZ SWAP
I would have if I could have found this site before I bought them. I searched internet for weeks trying to find specs on brackets with no avail. But After I bought I found this site and its everywhere. Just my luck
Old 12-20-2009, 09:31 AM   #11
1950 GMC
1950 GMC's Avatar
Re: AD vs EZ SWAP
I have a question for the AD guys. How high is the top bracket/plate off the frame not including the s10 spacers? The reason I ask is I found a truck that I like the stance of and want to copy it as much as possible, and they used the AD kit. I'm going to be copying jeffs51's design making the front 3.5" off the frame and the rear 3.75" off the frame. http://67-72chevytrucks.com/vboard/s...1&postcount=80
Thanks,
Garrett
Old 12-20-2009, 11:50 AM   #12
50adrod
50adrod's Avatar
Re: AD vs EZ SWAP
I. I didnt even move my engine since i had a nice running 4.3 liter in it.
I am confused about this, if you look at blue jeeps post and where his motor is http://www.67-72chevytrucks.com/vboa...d.php?t=369117
seems loke you would have to move it back. I ask because my motor is out and the frame is bare now and it would be much easier to move it back now.
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 12-20-2009, 01:02 PM   #13
BlueJeep
BlueJeep's Avatar
Re: AD vs EZ SWAP
Move it back now, you'll create much less work than after you figure out it won't work in the stock location.
Here's mine, uses the stock s10 rubber mounts, just back 7".
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
