Old 08-08-2009, 06:20 PM   #1
glenb
need help with hei rotor
Hey there im new to this.Picked up a 80 scottsdale 350/400/. when throttle is wide open, 4bbl kicks in but the engine is surging. can smell gas afterword.any ideas? also how do you get at the rotor to change it. Thanks
glenb is offline   Reply With Quote
Old 08-11-2009, 03:51 PM   #2
jd74c-10
Re: need help with hei rotor
there is a adjustment on the right side of the quadrajet secondary to adjust the tension on the top butterfly .when the butterfly opens it lifts the needles out of the main jets, when the tension isn't right the needles won't drop back in the jets and close off the secondary fuel. that could be your surging and fuel smell. check to see if the top butterfly close's freely when you open it by hand. to get to the rotor remove the distributer cap and there it is. hope this helps Jim
jd74c-10 is offline   Reply With Quote
Old 08-11-2009, 03:52 PM   #3
msgross
msgross's Avatar
cap comes off with four screw J-clamps located near the base of the cap. Make sure it goes back on the right way though..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
