cheap carb stand for work bench
Took my carb out today to check float level, couldnt find a good place to set it down, so I pulled out the plastic cut out that it came in and set it in there. Worked perfect, was able to work on it without resting the carb on the linkage, thought I would pass it on
laying low
![]() Join Date: Mar 2001
Re: cheap carb stand for work bench
Yeah that'll work. You can also use some 3" or so bolts with two nuts each to use as legs attached at the corner bolt holes of the carb.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
its all about the +6 inches
boog... i was just about to say the same thing!
