anyone got pics of 3in 4 in drop?
3in in front and 4 in back?
has anyone used brothers lowering kits? |
Re: anyone got pics of 3in 4 in drop?
ive never even heard of brothers lowering kits.
![]() Join Date: Jul 2006
Here you go, 4" coil springs out back, 3" lower controls arms up front:
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
thats still to high
i want go get my truck low but i dont want to have to change everything out! |
#5 | |
Tot Roddin'
For instance, we just tied up lowering my '69 4.5/6" and used 2.5" drop spindles, 2" front drop springs, 6" rear drop springs, new shocks, shock relocaters, disc brake upgrade..... etc. You could install bags without much modifaction to the current suspension, but it will require removing your springs, running lines, power, compressors, valves, tank... etc.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
4/6 drop doesnt look that low!
My truck is about thay low right now but i heated my springs haha |
#7 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Just replacing your heated springs? Using over a 3" drop spring in the front will cause alignment issues. Most 3/5 spring drops will require drop shocks. What kind of budget do you have for your suspension drop?
i understand im going to need drop shocks and spindles but i want a drop to were my tires go in the finders just a little!
Tot Roddin'
So you are looking for your drop to "tuck" your tires.
As lolife99 mentioned.... the next question we will have it, what's your budget? We can direct you to a mild setup, or go all out for the wild install.
This is my 5.5"/7.5" static drop on my '69.
I think you will need bags to get it lower. Also,... your front tires will have to "tuck" to be able to drive it this low.
a mild setup would be good!
i just want my truck to look low but good! that staic drop looks good |
drew,... my drop includes 2.5" drop spindles, 3" drop front coils, all 4 drop shocks, shock relocators for the rear, 6" drop rear springs, adjustable track bar, 1.5" drop blocks and a bolt in c-notch.
ALOT of stuff to change. If you have any questions,... just ask. We are here to get your truck riding low,...
#13 |
were did u get that kit from?
#14 |
Tot Roddin'
If you're referring to the kit lolife99 posted on his '69; he purchased the items separately from different vendors.
If you are looking for a kit which will include 99.9% of everything you will need, check out Early Classic Enterprises (www.earlyclassic.com). I purchased my 4.5/6" drop with disc brake upgrade from them, and had zero issues in installing it.
#15 |
If I was to use 3" spring in the front and 5" springs in the back would I have alignment or any other issues? Or would I be better of doing a 2" spring in the front and a 4" spring in the rear.
#16 | |
Señor Member
BTW, there is a LOT of information in this forum if you'll take a few hours of time to read the various threads that are already here. You may even find the answers to the questions you're having trouble formulating in this thread.
#17 |
lolife99 love the stance, what size tires are you running? and what shocks?
#18 |
1.5 coil cut from bb springs ece drop spindalls
![]() ![]() 4 in drop spring in back with 2in block ![]() ![]() ![]()
nickle and dime |
#19 |
looks like this now porterbilt style still underconstruction
nickle and dime |
#20 |
Tot Roddin'
You last couple of pics had me looking out the window... you had me scared there for a minute. I thought winter had come.
#21 |
That was in January lol.
nickle and dime |
#22 |
I'm running 215/70-15's up front and 275/60-15's in the rear. Front shocks are Belltech shocks I had,... and the rears are KYB"s from ECE.
