Old 08-09-2009, 01:22 PM   #1
eagleuh1
eagleuh1's Avatar
68 C20 Camper Special on the road again.
Got it back on the road after a 13 year absence. Rebuilt original 327, new seals and filter and fluid in painted original TH400, still shifts good. Cleaned up the original paint, little polishing compound here and there. New wheels waiting to be put on, gotta replace wheel studs with metric. Gotta replace cab supports, passenger cab corner and both sides rocker panels. Gonna do this soon and repaint original colors. Also the passenger inner fender and battery box need replacing. The AC even works, but needs R12. Radio works. Removed the back patio deck, so no more parties there, sorry. Had duel exhaust put on, nice and quite. So far have 25 miles since first drive. New HEI distributer sitting in cab waiting to be put in. So much to do, but worth it. Jim
eagleuh1 is offline   Reply With Quote
Old 08-09-2009, 01:27 PM   #2
eagleuh1
eagleuh1's Avatar
Re: 68 C20 Camper Special on the road again.
Also replaced the rams horns with Flowtech headers. The rams horns leaked everywhere, pretty bad shape from prior long term leaks. The headers fit perfect and easy to put in.
Old 08-09-2009, 04:22 PM   #3
GR8-68
GR8-68's Avatar
looks like a great truck to start with , keep us updated on it
GR8-68 is offline   Reply With Quote
Old 08-09-2009, 06:45 PM   #4
factorystock
factorystock's Avatar
A very solid truck with nice options.Good luck on project. A little blurry, but it looks like a leaf spring rear end and 4.11 ratio options on the SPID? Also, Is it a eaton rear (round) or dana rear?
factorystock is offline   Reply With Quote
Old 08-10-2009, 10:57 AM   #5
eagleuh1
eagleuh1's Avatar
The Dana 60 rear end. Thanks for the comments. Jim
Old 08-12-2009, 09:20 PM   #6
That`s great to see.I have a thing for Custom Campers.Where did you get Camper Special from?It`s a Custom Camper,FYI.(like on the fender badge)
Old 08-13-2009, 12:53 AM   #7
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
congrats on getting her back on the road! I just drove my 68 3/4 gmc camper special on sunday for the first time in 10 years. It feels good to get it back on the road.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 08-13-2009, 04:57 AM   #8
Pre-73 = Custom Camper.
Post-72 = Camper Special.
Ford = Camper Special
The use of "Custom" was the rage in trucks of the`60s,then faded away in the`70s.All the Big 3 called their upscale trucks Customs or in ford`s case,Custom Cab.Ford`s base full-size car was a Custom.In the`50s it was Deluxe.I don`t mean to be anal,and actually I`m not.It is what it is and a name`s a name,that`s all.
Old 08-13-2009, 08:44 AM   #9
eagleuh1
eagleuh1's Avatar
Sorry, Custom Camper. My bad. I'll have to actually start reading my fender badges before I log on. Anyways, got the HEI distributer in and hopefully setup right. Starts a lot quicker. Burned and had to replace one wire because it flopped over onto header before I put the looms on. Crap. Next is to get vacuum guage and tach and try and set the carb up perfect. Spent yesterday removing all the old exhaust hangers and electric pump and tubing and wiring for the custom camper pumping system previous owner had left on it. Washed out another 5 lbs of dirt from underneath first at the car wash. Much better when you aren't blinded by falling debris all the time. Jim
Old 08-13-2009, 08:52 AM   #10
70cst
70cst's Avatar
Is that a 50th? Hey nice truck. I am gald to see another truck back on the road. Hopefully someday I will get the Circuit Rider back on the road.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-13-2009, 10:59 PM   #11
That`s all the stuff I do.Get the crud off,mud,grease build-up,and unecessary crap like left over bolted on stuff.
