lowering the rear again
Thanks for everyones help in advance.
1985 c10 silverado I have lowering blocks in the rear and want to change over to a better system Just a good basic kit. i lowered it with blocks to keep some of the load capacity. i use the truck for work. Will i be able to carry the same weight with a flip kit or do i have to go with helper bags. Thanks |
6.0 powered square
Re: lowering the rear again
with the lowering blocks you already have a flipped axle
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
very sorry about how i phrased the question. i want to install helper springs for more load capacity. should that be a problem with the flip kit.
Thanks |
67-72 parts collector,…
![]() Join Date: Nov 2002
Is your frame notched?
Did you remove any of the original springs from the spring pack? Any chance you have pictures of your rear suspension?
here are some pics of the rear. looking to put bags, shocks or springs. I love the stance of my truck but need more capacity.
thanks |
All plates were welded. As you can tell it was done about ten years ago.
I have car A.D.D.
I think you should be able to run a helper bag set up on it without compromising the height.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 08-09-2009 at 05:50 PM. |
Thanks. Any suggestions on a good product?
I have car A.D.D.
I have never used them but I think AirLift makes a good quality product tat is universal fit. You should contact one of the AVS guys on here. They are vendors on the site and may have something available as they do air suspensions.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
Thanks again.
AirRide Technologies also make a "air-over-leaf" kit for your truck.
Do you plan on running a tank and compressor or just adding a set of schrader valves? Also,... post up some pics of the whole truck. It looks really clean!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-09-2009 at 06:10 PM. |
#13 |
No tanks just a schrader valve will only need to use it a couple of times but when i need it i will have it.
Thanks i think it is clean . |
#14 |
I've used the air lift bag/shock combo on my 93 subby. They worked great as I occasionally towed my 20' car trailer. They rode well too. You can either air compress or schrader valve set up.
They were NOT cheap though ..... about $600 bux. I should have removed them when I sold it. Ratty 46 |
#15 |
thanks guys i will start my search on the info you have givin me.
