htg a/c control cables
Cables dont want to slide through housing very good. has any body had luck soaking in penetrating oil or do they make repo that has teflon inner so it slides better than stock ones?
Re: htg a/c control cables
Penetrating oil does help. Have you checked for kinking of the inner cable?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I went out after work pulled 1 cable off to experiment soaked in penetrating oil straightened inner cable a bit seemed to free up some. guess ill try another tomorrow. Thanks for the input. inner cable did have slight kink. the cable is just basically a wire running through a coiled wire housing its a wonder they dont make repo cables with teflon inner for cable to slide freely.
