Old 08-09-2009, 09:39 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
wow more truck problems
ok so some times my tranny wont shift like just randomly it stay in what gear its in and wont change ...and when i shut down my engine its sound likes its still trying to run for a second or so like sputtering and junk
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 08-09-2009, 09:57 PM   #2
83burban
Re: wow more truck problems
1 problem at a time:
Transmission (what type as well):
Fluid level, color, smell?
Not up-shifting or down-shifting?
Not changing gears when hot, cold, both?
Does it happen at all times of driving or just when your gunning it?
Engine (Seem to remember 400 sbc):
When you go to turn it off does it at like it is dieseling or does it just sputter then shut-off?
Do you know what your timing is set at?
How do the plugs look?
Answering those questions should give me and the rest of the board a good idea collectively of what might be going on.
Kurt
83burban is offline   Reply With Quote
Old 08-09-2009, 10:01 PM   #3
silvereagle07
silvereagle07's Avatar
On the trans problem 1. What trans do you have? 2. Can you manually shift the trans with no delay? On the engine issue, it sounds like your timing is off.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 08-09-2009, 10:07 PM   #4
pokethesmot
th350 and i think it is only when it is warm also it wont up or down shift i have to just keep moving the lever around untill it finly shifts and its like when im stopped and i have no idea what my timing is set at also it like sputters for a little bit then shuts off and the plugs are brand new so they should be good and about the smells my engine has always had a burning oil smell but thats just cuz i got a real small valve cover leak lol i think
Old 08-09-2009, 10:13 PM   #5
83burban
burning oil wouldn;t be the cause of either of the problems you listed.
You need to check the trans fluid for level and color. Sounds like maybe you filter is getting clogged and that's causing it to not shift. I don;t want to say that for sure before you give more info, but it is a possibility.
Does it ever slip?
When you manually shift gears do they engage right off or do they lag?
Does the engine change RPMs dramatically during the shift?
You should probably get the oil leak fixed, but I doubt its the root cause of the issue. I would check your timing first, or find someone to check it for you.
Did the "sputtering" occur after you changed plugs, or ahs it always been an issue?
What did your old plugs look like?
Old 08-09-2009, 10:17 PM   #6
pokethesmot
Does it ever slip?
the sputtering just happened randomly and my old plugs looked great and it dosent mess up while im driving even thoe it use too but it stopped doin that...now it only dosent shift when i stop and then change to revers or when im in park and change to drive or reverse
Old 08-09-2009, 10:27 PM   #7
83burban
describe sputtering. Does it act like it still wants to run or what?
for the tranny i don't know what to tell you, more knowledgeable people will jump in i'm sure. But check the fluid level, color and smell and post up what it is.
Old 08-09-2009, 10:30 PM   #8
3r!c84
Badass
3r!c84's Avatar
poke i told u, you would be back in a week with another problem lol
yea i would change the filter and atf
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-09-2009, 10:35 PM   #9
pokethesmot
it acts like its running real ruff and slow like it shakes alot like a dying animal its trying to run but no abilty
Old 08-09-2009, 10:42 PM   #10
83burban
Sounds like the motor is dieseling. What part number plugs did you use?
I am assuming that it only acts like this after it turns off at operating temp. Run it for 60 seconds after the engine has cooled completely then turn it off. If it doesn't diesel my guess would be you got the wrong plugs in there
Old 08-09-2009, 11:02 PM   #11
pokethesmot
well even at operating temp some times it wont do it but yet it only does it when its warm
Old 08-09-2009, 11:17 PM   #12
thirdstreettito
Resident of Here
thirdstreettito's Avatar
You are 16, I am 16, we both have constant and ongoing truck problems with our SWB 81-87 K10s...we sure can pick em.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-09-2009, 11:25 PM   #13
pokethesmot
lol i know right but im not 16 lol im 18....close enough thoe
Old 08-09-2009, 11:26 PM   #14
3r!c84
Badass
3r!c84's Avatar
your 16?
im 17 i was thinkin im the only "kid" here lol
-00 Saturn 5spd
1/4:13:90
Old 08-09-2009, 11:36 PM   #15
Rollinsqrbdy
Rollinsqrbdy's Avatar
Poke- Im sorry bro but, u got some bad luck I hope you can fix it.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 08-10-2009, 12:13 AM   #16
thirdstreettito
Resident of Here
Originally Posted by 3r!c84 View Post
your 16?
There is actually a 13 year old on here. I seem more like 35 though, I've been wrenching on everything non stop for 16 years, plus Im not the normal retarded 16 year old, I dont even know how to text.
~Bradley~
Miss having a truck
Old 08-10-2009, 02:04 AM   #17
pokethesmot
could the dieseling be cuz my idle is set a little high...i noticed today that my rpm at idle is reading 2000 and is it hard on my engine
Old 08-10-2009, 02:09 AM   #18
willett
Another Day, Another Dollar
willett's Avatar
try shutting er' down in gear, and don't burn sh*tty fuel.
occasionally my 454 deisels if i turn it off in park.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 08-11-2009, 03:41 PM   #19
jd74c-10
sounds like the vaccum line to the transimssin fell off.that will mess up the shiftting plus cause the engine to diesel and try to keep running. always look for the simple things first! Jim
jd74c-10 is offline   Reply With Quote
Old 08-11-2009, 05:04 PM   #20
pokethesmot
well i re tuned my idle and my carb and i think the dieseling stopped also i checked the transmission fluid and it was at the right level and looked ok...the only thing im kinda wondering about is that i checked my engine oil while the truck was running and it says it is way way over filled....could this be right cuz it shouldn't be
Old 08-11-2009, 05:24 PM   #21
sperz1
sperz1's Avatar
You should always check your oil when the engine is in the off position. Your truck is fine.
sperz1 is offline   Reply With Quote
Old 08-11-2009, 05:40 PM   #22
pokethesmot
lol ok i thought so
Old 08-11-2009, 06:08 PM   #23
dieseldr4
chech the vacuum line from the engine to the modulator on the transmission.. i say this because:
1)sudden higher than normal idle would suggest a vacuum leak
2)th350 wont shift right= no vacuum to the modulator...
3)if those 2 things arent connected it will produce a syptom like yours...
see how that works for you.. hope it helps...
be a site supporter
dieseldr4 is offline   Reply With Quote
