Old 08-09-2009, 10:40 PM   #1
JET4x4
Question No brake pedal
Well I'm not sure what to do next with this problem. Working on a friends 85 k10 with a 6.2 diesel. The brake pedal goes all the way to the floor and the truck barely stops. No brake lines are leaking. We've checked the wheel cylinders, adjusted the back brakes, and bled front and rear brakes several times. We also put a new master cylinder on it, but it still has the same problem.
I'm stumped and looking for other opinions. Thanks in advance.
67 Chevy K20 LWB Fleetside project
85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project
86 m1009 blazer, 6 in lift, 35's, driver
69 c10, 307, long bed, 3 speed, driver
07 Dodge 2500, cc, lb, cummins turbo diesel
00 z28 camaro, ls1, 6 speed, rarely leaves the garage
JET4x4 is offline   Reply With Quote
Old 08-09-2009, 10:47 PM   #2
83burban
Re: No brake pedal
bench bleed the master?
83burban is offline   Reply With Quote
Old 08-09-2009, 10:52 PM   #3
JET4x4
Re: No brake pedal
Yup. And no air comes out when bled at each wheel. I'm thinking new master might be defective.
Old 08-09-2009, 11:00 PM   #4
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: No brake pedal
I went threw 2 or 3 from autozone before i got a good one!
1985-GMC is offline   Reply With Quote
