Old 08-10-2009, 09:32 AM   #1
Jim_PA
Black material between outer and inner roof...
What is it? What should I replace it with?
Or should I use the somewhat torn up piece I removed?
Jim_PA is offline   Reply With Quote
Old 08-10-2009, 09:56 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Black material between outer and inner roof...
Any pics? What's it look like and where exactly is it? I've never seen any stuff like that in my trucks before.
68gmsee is offline   Reply With Quote
Old 08-10-2009, 10:02 AM   #3
Jim_PA
Well, I just realized I threw the old piece away... but, I cut a patch out of a good roof, and this sheet of black sticky material was laying between the outer roof skin, and the interior roof.
It seems like it might be the same stuff they use under the carpet? Does it even need to be there...?
Old 08-10-2009, 10:15 AM   #4
turp mcspray
turp mcspray's Avatar
Sounds like sound deadener. Probably not critical but a good idea to have. If you need new, check with a body shop supply store. 3M and other companys make a similar product.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-10-2009, 10:48 AM   #5
cdowns
cdowns's Avatar
well if i had the two apart i'd sur try to get some sound deadner /insullation up in there for a better interior comfort quality
Old 08-10-2009, 11:23 AM   #6
Jim_PA
Ok, just wanted to make sure it wasn't something specific. I'll start checking out sound deadners for the whole thing while I'm at it.
