Old 08-10-2009, 05:00 PM   #1
brew8
early X-over steering
Those of you that kept the closed knuckle axles in the front of your early 60's 4x4, if you put in power steering did you keep the original drag link or put in the later stuff with the doner steering box, did you use a long or short pitman arm, and have any of you put in a x-over steering system with the closed knuckle, if so where did you get steering arms for it? Thanks in advance, cheers, Larry
brew8 is offline   Reply With Quote
Old 08-11-2009, 06:18 AM   #2
duallyjams
duallyjams's Avatar
Re: early X-over steering
Cross over steering can not be used with a closed knuckle front axle, you need a d44 flatop axle or d60 axle and a 2wd steering box,plus the closed knuckle has drum brakes the other two axles have disc brakes then you would have to change the master cylinder also.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
