Old 08-10-2009, 11:41 PM   #1
mas09ts
mas09ts's Avatar
Anyone used these?
Any one used Summit headers, http://www.summitracing.com/parts/SUM-G9006/ i know they're cheapos but they look like fairly decent ones.
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 08-10-2009, 11:54 PM   #2
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: Anyone used these?
if your going to lower it any I suggest these
http://www.summitracing.com/parts/HED-69640/
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 08-10-2009, 11:59 PM   #3
mas09ts
mas09ts's Avatar
Nah im not gonna lower it.
Mitch
22yrs. Young
Old 08-11-2009, 12:24 AM   #4
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
I've used em. Good headers, good fit, they're not gonna look amazing but hey they work so why complain for 90 bucks?
mikajo39 is offline   Reply With Quote
Old 08-11-2009, 11:44 PM   #5
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Only question is how long will they last before they rust out?
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 08-12-2009, 02:10 AM   #6
rick0312
rick0312's Avatar
i installed them. i stripped them down and repainted them with high heat paint. I haven't run them yet, but they came out nice. don't know if the paint will stick once they heat up, but they look good now.
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 08-12-2009, 06:40 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you will look closely at them down by the collector, you will see a Dynomax part number.
Old 08-12-2009, 01:57 PM   #8
mclairmo
Get the ceramic coating. I have had it on my Dynomax headers for 15 years with no problems at all. Paint will burn off and then they will rust.
mclairmo is offline   Reply With Quote
Old 08-12-2009, 06:02 PM   #9
Gumby'sC20
Gumby'sC20's Avatar
I got the same ones branded as Dynomax. They work well and improve power, yes. The paint, again as stated above, will heat, chip and fall off. Mine haven't rusted yet. For $80 you can't argue. I think I had to put a slight dent in one of the pipes to route it a little bit smoother over one of my frame rails but thats it.
...oh and the AC compressor needed to leave the bay.
Gumby'sC20 is offline   Reply With Quote
Old 08-12-2009, 08:04 PM   #10
stevewhitmore
stevewhitmore's Avatar
I just installed a set of the same headers last night with the ceramic coating and they fit and look great Was also an easy install for my first doing headers.
Well worth the $187 compared to others.
stevewhitmore is offline   Reply With Quote
Old 08-12-2009, 08:27 PM   #11
SS68
SS68's Avatar
when buying headers does flange thickness matter
SS68 is offline   Reply With Quote
Old 08-13-2009, 01:43 PM   #12
stevewhitmore
They say the thicker the flange the better because of less chance of warpage but if the bolts are kept tight they will not warp. I check mine about evey 30 days and they do get loose. I took the same Summit headers (rusty) off and they were on there for years with no problem. The rust is why I went with the ceramic coated this time.
Old 08-14-2009, 05:24 PM   #13
70duramax
i'd stick with the factory ramhorns you won't notice any power gains just headaches or save up and buy a nice pair! just experience and my .02cents good luck
70duramax is offline   Reply With Quote
