Old 08-11-2009, 12:44 PM   #1
rci2990
headers
got a 70 c-10 that i put a 400sbc into,i had a set of dynamax headers laying around that i put on.i have alum heads on and the # 3 plug wouldnt go in untill i dinged the header.and even then the boot will be touching the header.my question is,is there headers that have the angle in so i can use them or whats the limit in dinging the header more.im just worried about putting a hole in the header or the boot cracking from the heat.thanks
1970 c-10 2wd longbed
rci2990 is offline   Reply With Quote
Old 08-11-2009, 04:03 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: headers
Have you tried Accel shorty plugs. They are suppose to give you more clearance for the boot, since they are about 1/2" shorter.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-11-2009, 04:40 PM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
Re: headers
I've never run those headers. But I've run the cheapest headers known to modern man: Summit Headers! Although it is tight around that #3 plug, it's always fit for me and I've never burned a boot... fingers? Heck yes! But boots? no...
69GMCLonghorn is offline   Reply With Quote
Old 08-11-2009, 05:21 PM   #4
mclairmo
Re: headers
You can ding the headers more if you heat them with a propane torch, which is what I did to mine. if the boots are touching the header, they will still last a long time, but eventually the boot rubber will get burned off. Try the shorter plug and maybe a 45 or 90 degree boot. I think I read that Champion also makes some shorter plugs.
mclairmo is offline   Reply With Quote
Old 08-11-2009, 08:11 PM   #5
fdbdw
fdbdw's Avatar
Re: headers
my #5 was touching and I used , shorty plugs, straight boot wires and protective sleeves, its a pain but between all 3 its worked out well, you can also buy ceramic boot wire sets that are rated to withstand high temps but they are a bit expensive I havent heard anyone that has used them so dont know how well they work, good luck
fdbdw is offline   Reply With Quote
Old 08-11-2009, 09:51 PM   #6
rci2990
Re: headers
i tried the ac delcos but way too long,i found ngks that were shorter.ive heard too many bad things about the accel shorty plugs not to mention there twice the money.im gonna heat it up and ding it abit more.thanks.
