Gas tank sending unit gasket replacement?
I've got a slow seep out the front if I fill it too full and I want to fix it.
How does the lock cam come off of there? Will it be reusable? I just made a big order yesterday to get free shipping and now I realize I need a gasket and probably a lock cam...only a few dollars...shipping will cost more! I have called around to all the local places and they say they don't have a gasket.
'67 C-10 Shorty - 454, 5spd, and speed holes! |
Re: Gas tank sending unit gasket replacement?
you just hit carefully on the lock cam to loosen//if you dont get carried away it is reusable
the "gasket is an oring available at parts and hardware stores cheap
I did tap on it a bit. Hit where? How? Does it just pop out of there? I won't need to pry? Any pics?
I called the place and had them throw in a gasket and lock cam on my order, so I am good there...just need to get it out now. ![]() Thanks!
there are tabs that stick up you tap on them to loosen counterclock
Right, just tap on one of the tabs... you basically have to un-screw the lock with a few taps from a hammer/screwdriver. When it starts moving, you'll be able to see when you have to stop tapping.
I found that the stock lock ring was a bit stiffer than the aftermarket, and re-used my original. |
Neighborhood Pickle Slinger
I remember taking mine out. Just like cdowns said, there should be 3 tabs that are on the ring. Tap them counterclockwise without too much force and donīt concentrate on one, tap them each a little bit til the ring loosens and then you can take it off the rest of the way with your hand.
The ring kind of looks like this one when you get it off. ![]()
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
Be careful not to make any sparks when tapping, or kaboom.
Thanks guys...got it. I will have to compare the new lock ring with the old one as far as stiffness goes. I was thinking that exact thing Mclairmo after I struck it once. I got a rubber cover for the end of my screwdriver right quick!
I instaled that tank and cant get fuel to fuel pump. I used a 5 gallon can to feed fuel punp.Do i need a electric fuel pump?
