Old 08-11-2009, 02:33 PM   #1
degree01
can some one please tell me what year chassis this is?
I have a 66 chevy truck that has a newer model Chassis but cannot find what chassis this came from, can some one please point me in the right direction? thank you in advance.
degree01 is offline   Reply With Quote
Old 08-11-2009, 03:38 PM   #2
rookierodbuilder
rookierodbuilder's Avatar
Re: can some one please tell me what year chassis this is?
Looks to be a 73-87 c-10 frame.
rookierodbuilder is offline   Reply With Quote
Old 08-11-2009, 06:01 PM   #3
degree01
Thank you, i think you are right, i just looked at a 78 chevy truck frame and seems to be the same, I appreciate your response.
Old 08-11-2009, 11:07 PM   #4
Captainfab
60-66 Nut
Are you planning on changing the frame or working with that one?
Old 08-12-2009, 09:29 AM   #5
degree01
No im working on this one, i started with the engine and im down to the bed it just has some differences when it comes to laying the bed on it, the reason i took the bed off is because the last person who had it just welded the bed to the frame using some steel bars and that is why I took it off, i plan to put the bed on it the right way so i have to try and modify it to fit right.
Old 08-12-2009, 01:27 PM   #6
rookierodbuilder
i would say your best bet would be to modify your front and rear mounting points on your bed first. the tailgate should have a bar on the back with brackets welded to it for mounting the bed. I would move those, the front should be a matter of measuring for proper spacing and re-drilling the mounting holes and adding the proper spacers.
Old 08-12-2009, 02:40 PM   #7
degree01
yeah that's what i was thinking of doing, the frame did not have any brackets, but i took some off a 70's truck so i will start to measure and attache the brackets where they should go.
Old 08-13-2009, 12:24 AM   #8
Captainfab
60-66 Nut
I put a '62 body on a '74 frame once. Personally I didn't like the way it turned out.
Old 08-13-2009, 09:08 AM   #9
degree01
Yeah im not to crazy about it either, if it was up to me i would get the original frame but money wize i can't afford it right now so im going to work with what i have, I have done most of it i just need the Bed mounted and i really don't think it will be hard to do. I will try and post some pic's of my truck when i have a chance.
