08-11-2009, 06:37 PM | #1 |
Cab Corners?
Greetings,
So we replaced both cab corners on the 72'. Now we notice that the lower portion of the corner to the cab floor is open. Kinda looks like something is missing, like maybe insulation or something? Any help is greatly appreciated. MrBlue |
08-11-2009, 07:12 PM | #2 |
Re: Cab Corners?
I am not sure exactly where the hole is but the factory sprayed in a foam like material to cover the joint between the cab corner and the rocker area.
You could also weld in a piece of sheet metal. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
