Old 01-10-2003, 01:33 PM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Has anyone ever popped an airgbag?
I had a thread going about air bags. I want to hang a bag on the frame and grind the bolts off the bottom so I can travel beyond the limit of the airgbag. This would leave my bag "uncontained" with pressure in it. Some think the bag would pop, some say no, No one has ever done it, so who knows for sure.
I am interested to know it anyone has ever popped an airbag and what caused it.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 01-13-2003, 09:32 PM   #2
BIGG BELLY
i was playing with some old bags--checkin travel and stuff--i put 100 psi in it "uncontained" with no problems--but that was only once or twice
55 big window long bed
69 olds 98
check out my pics
photo albums
BIGG BELLY is offline   Reply With Quote
Old 01-14-2003, 11:59 PM   #3
sawzall
bad idea
I think havin the bag uncontained at the bottom would be a very bad idea, i dont think the bag would pop due to pressure however I think that when the suspensinon unloads the trailing arm would rebound and eventually catch the side of the air spring thereby pinching the bag and tearing it.
if this were to happen you would most likely have a sudden failure. making a bad situation worse..
you want to do this for what reason???
sawzall
1940 ford
1946 ford
1948 ford truck with 67 chevy truck chassis
sawzall is offline   Reply With Quote
