Manual Trans Electrical Switch Identification Help?
After an hour or so of searching...I give up...
Little Help Please..... What is the switch that is located on the top of this trans and where can I get one?....also, am I correct that the other switch on the side is for the reverse lights? Thanks in advance! ![]()
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
Just Not Low Enough!
Re: Manual Trans Electrical Switch Identification Help?
you are correct on the reverse light switch, the other i dont know, im sure someone will chime in.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
its all about the +6 inches
the back up light is the one on the side if I am not mistaken. The other one is part of an early smog control deal, TCS transmision Controlled Spark. It would prevent the Vac Advance on the dist to work unless you were in top gear and engine warmed up.
Back in the sticks
Hmm, makes me think, where is mine on the Blazer? Can you get replacement switches at any parts store?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
So, sounds like I should just plug that hole huh?....not really needed?
Is there anything else I will need to take into consideration if I simply plug it? Thanks, Dan
the turbo charger might not work correctly if you unplug it. I'm just saying.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 08-12-2009 at 12:59 PM. |
Nah... that one goes to the muffler bearing sensor.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
maybe,... or the headlight fluid sensor....flootenator valve possibly
Piston return spring lash adjustor??
hahahahaha, now the whole office of women I work with are all wondering why I'm laughing so hard over here at my desk. You guys rock
