08-11-2009, 11:02 PM | #1 |
Rear inner splash shield?
The truck is a 72 GMC I have not been able to speak with previous owner yet,it has 20 inch wheels on it. The splash shield are removed, would that becaused of the 20 inch wheels?
08-12-2009, 09:07 AM | #2 |
Active Member
Re: Rear inner splash shield?
ttt:
Do you mean rear wheel housings (#9) on the bed or the splash shields (#10)on the bottom behind the tires? http://www.lmctruck.com/icatalog/cb/full.aspx?Page=25 I've heard of some removing the rear wheel housing or tubs to make room for fatter tires but haven't heard of removing the splash shields for that reason. |
08-12-2009, 03:09 PM | #3 |
Yep its #10 I just got the truck and the owner was not around.So maybe I need to take the rear tire off to see if they fit with both on.
08-12-2009, 03:13 PM | #4 |
What's the diameter of your rear tires? I wouldn't think the splash aprons would be a problem.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
