Old 08-12-2009, 01:44 AM   #1
harry
harry's Avatar
autometer fuel gauge
hi guys does anyone know what needs to be done to for an autometer fuel gauge to work with standard 63 fuel sender unit or will it work ok???.
Standard sender unit has been tested and works,I have seen this question here before but cant find the thread,cheers
harry is offline   Reply With Quote
Old 08-12-2009, 07:37 AM   #2
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: autometer fuel gauge
Harry, have you tried it yet? If you have the correct gauge (0-30 ohm, autometer sells them in several ohm ranges) it should be OK.
Larry
fleetsidelarry is offline   Reply With Quote
Old 08-13-2009, 12:18 AM   #3
Captainfab
60-66 Nut
Autometer does offer 0-30 ohms fuel gauges, but only in certain styles and sizes. If you already have a gauge, you may be able to use a resistor to make it compatable with your '63 sender. It just depends on which gauge you have. You might try sending a PM to Vin63, he rebuilds fuel sending units.
Old 08-13-2009, 03:10 AM   #4
harry
harry's Avatar
thanks guys the guage is an autometer phantom series but i will try it out as i know the sender unit works fine now cheers
Old 08-13-2009, 10:25 AM   #5
slepysal
slepysal's Avatar
Larry
thats waht I did, and it works like a charm
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
