Old 08-12-2009, 07:28 AM   #1
Patsfan34
Patsfan34's Avatar
Front clip question! (Swapping grill)
I came across a 71/72 front clip in great shape but when it's time to put the body on the truck I want the 69/70 grill. I know that the 67/68 front clip is not interchangeable with the rest of the years but isn't all the 69-72 front clips all interchangeable regarding grills and hoods and pretty much everything?
Thanks,
Patsfan
Patsfan34 is offline   Reply With Quote
Old 08-12-2009, 09:25 AM   #2
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Re: Front clip question! (Swapping grill)
the bumper is different, 69-70 smooth, 71-72 holes for signals. I think the hood latch and center support are different. and obviously the grill. other than that they are the same. Unless I forgot something.
stealthy '69 is offline   Reply With Quote
Old 08-12-2009, 10:28 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
stealthy '69 is correct. Hood latch and center support are different.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-12-2009, 05:35 PM   #4
Patsfan34
Patsfan34's Avatar
Does this mean a 69 grill will not be a direct bolt-on to this 71/72 front clip I'm about to buy?
Thanks guys!
Old 08-12-2009, 05:43 PM   #5
daves69
I just bolted a 71/72 grill onto my 69. I had to trim the middle part of the center support and also cut about 1/2 inch of the latch handle. It's not a difficult switch though and well worth it if you get a better looking grill out of it.
81 Blazer
69 C-10
daves69 is offline   Reply With Quote
Old 08-12-2009, 05:52 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
Thanks guys!
You'll need a '69 hood latch and center support, the '69 bumper is different as well.
Beat it to fit,
Old 08-12-2009, 06:55 PM   #7
71swb4x4
71swb4x4's Avatar
I assume you know this, but thought I would point it out just in case. As long as you are talking Cevhrolet vs Chevrolet, everything above is correct.
If you are mixing 71/72 GMC and with 69/70 Chevrolet then it is not correct. If that's the case, let us know so we can point out the differences.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-12-2009, 08:25 PM   #8
stealthy '69
'69 Chevy SWB
good point I didn't think of that
Old 08-12-2009, 08:33 PM   #9
SS68
SS68's Avatar
what is the difference in hood latches? is the 71 and 72 hood latch better? if i get a new one will it keep my hood from jumping when i hit a hard bump on the road?
SS68 is offline   Reply With Quote
Old 08-13-2009, 09:39 AM   #10
Patsfan34
Patsfan34's Avatar
Thanks again all!
Old 08-13-2009, 11:43 AM   #11
stealthy '69
'69 Chevy SWB
You need to adjust your side stops down or the spike on the hood need to be adjusted out a little. More then likely the later of the 2
