![]() Join Date: Apr 2005
98 Fbody manifolds, New 5.3 truck oil pan with pickup tube
If you're doing an LS1 swap into 67-72 truck, these will work with ECE motor mounts with NO frame modifications. Here's pictures to prove it,
![]() Manifolds $50 + shipping. Oil pan $60 + shipping
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-23-2009 at 11:02 AM. |
Re: 98 Fbody manifolds, New 5.3 truck oil pan with pickup tube
Im interested. Do these have the egrport on them?
Are you talking about this?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: May 2007
put me second
![]() Join Date: Jun 2009
I was looking for a set of these cheap. However, I think I have talked myself into a pair of the Doug Thorley's. Will a stock f-body pan work?
#6 | |
Thanks, I will let you know as soon as Henson gets back with me.
R/
Well I have an f-body ls1. I was wondering if the stock pan would work. I guess I really won't know the answer to that until I get to that point. I have a fatman fabrications mustang II front end that I have yet to bolt up anyway. (I'm sanblasting the frame right now.) I might need a truck pan later, I don't know yet. Good luck with the sell
found a set on EVILbay so i am out!
MEMBER
Hey hart Rod I am interested in the pan what year and model vehicle did it come off of I dont even know what an f body is I have a 5.3 from a 07 tahoe and it hit a curb and cracked the pan and now I have the engine and I am dropping it in my 72 2wd blazer. I just want to make sure its the pan I need also whats shipping to 92840 whatever is easiest for you....I think the stock tahoe pan will work on my blazer ? and thats what I need...local13hutch....Let me know...
86 sub 4wd, 1 ton, duallie, big block th475 72 c10 short fleet, pro street 72 K/5 blazer,2x4 almost stock 72 3/4 ton sub 4x4 61 morris minor pickup, chevy 4.3 v6 03 escalade, 24" momo's wifes 96 2wd 2door tahoe 67 2wd suburban 72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo. ![]() |
#10 | |
#11 | |
bttt
#13 |
MEMBER
Hart rod/PM sent
#14 |
ttt
#15 |
![]() ![]() Join Date: Dec 1999
PM sent.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#16 |
Next project: 1970 K10
Hey Rob, are those manifolds cast? I'm wondering about removing the EGR ports and welding them shut. Whether I use the truck manifolds or f-body manifolds, I want to have them coated so I want ot keep them clean.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#17 |
They're steel and could easily be welded up. LMK.
#18 |
bump
#19 |
bttt
#20 |
bttt
#21 |
Anyone??
#22 |
ttt. I can deliver to cruizin the coast if paid for in advance...
#23 |
ttt
#24 |
bump
#25 |
computer illiterate
got any pics of the oil pan? i have a 5.3 out of a 2000 silverado i put in my 2wd blazer with ece mounts and the pan hangs under the crossmember about an inch or two. will your pan solve this problem?
72 2wd blazer 72 swb 4x4 |
