Old 08-12-2009, 11:13 AM   #1
nsuengineer06
nsuengineer06's Avatar
Frame mount booster-m/c question...
OK guys, time to put your collective genius to some good use..
I know somewhere on here I have seen it done, but haven't been able to relocate that particular build. I want to use a frame mounted master cylinder/booster combo. My question is this: How do you operate it? Would you use the old hot rod type pedals that come up through the floor or set up some type of multiple lever contraption..? I also thought of building a cable operated lever setup? I am a bit skeptical of using a cable setup for fear of it failing under emergency STOMP load.. lol
Any thoughts appreciated.
This is the type I want to use.
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 08-12-2009, 11:33 AM   #2
nsuengineer06
Re: Frame mount booster-m/c question...
Found it! Nevermind.. lol I guess I just wasted more space on the board...
1971 C10 SWB
Old 08-12-2009, 09:04 PM   #3
BP68
BP68's Avatar
Post the link you found here for others.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 08-13-2009, 12:05 AM   #4
ERASER5
ERASER5's Avatar
Those things are great for guys wanting to smooth their firewalls.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-13-2009, 08:54 AM   #5
nsuengineer06
Here is a link to the unit produced by Scott's Hot Rods..
1971 C10 SWB
